obd2 ... 2 o2 sensors..?
Old Jun 28, 2007 | 08:51 AM
stratedrm's Avatar
Default obd2 ... 2 o2 sensors..?
i did a b20b swap into my eg coupe... im running an obd2 ecu (with 1-2 adapter) and motor.. its throwing a CEL.. and i think im supposed to be running 2 o2 sensors.. is this correct?
if i am.. where do i add one in onto the harness?
Old Jun 28, 2007 | 08:52 AM
stratedrm's Avatar
Default Re: obd2 ... 2 o2 sensors..? (stratedrm)
i also have the option to run a obd1 ecu.. if i do that what would i need to change to make the motor run correctly?
Old Jun 28, 2007 | 08:56 AM
ef_hatchback's Avatar
i would just run a obd1 ecu on that. anyways, y are you running a obd2 ecu in a obd1 car???
Old Jun 28, 2007 | 08:57 AM
fmrprojects's Avatar
just swap in the obd-2 ecu and it wont have a code. motor will run the same. there are many ppl using obd-2 motors with obd-1 ecu, runs the same
Old Jun 28, 2007 | 02:12 PM
stratedrm's Avatar
the obd1 ecu causes a varying idle and rev... it runs just fine on the obd2 ecu.. i drive it around daily.. but i wanna try to kill the CEL if i can
brendan427
Oct 16, 2012 10:30 PM
strictly.business
Nov 25, 2006 09:05 PM
Bimmerman
May 25, 2005 02:16 PM
blackflag188
May 21, 2004 07:58 AM
43MA
Oct 30, 2002 04:58 AM
