cluster help
Old Jun 25, 2007 | 02:28 PM
Midori Green's Avatar
Default cluster help
i need to buy a new cluster for my car... i have a 93 ex coupe i would like to buy an si cluster or a gsr cluster... what parts do i need besides the cluster itself to make it work?
Old Jun 25, 2007 | 02:30 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: cluster help (Midori Green)
If you get a 5th gen cluster if will work fine with your factory wiring.
Plug and play.
I don't think there's much involved in wiring up a gsr cluster, maybe a little re-pinning.
Old Jun 25, 2007 | 02:53 PM
Default Re: cluster help (ek forever guy)
my mph stay at 0... and my vss is fine so im guessing my cluster is bad right??
Old Jun 25, 2007 | 03:03 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green &raquo;</TD></TR><TR><TD CLASS="quote">my mph stay at 0... and my vss is fine so im guessing my cluster is bad right??</TD></TR></TABLE>
Yeah, most likely, the speedometer heads go on clusters, it's not completely uncommon.
It'll work fine, as long as it's the same generation. As far as bolting in though, you'll have to use pipe straps to get the holes to line up, and the bezel won't be 100%, but it's definitely a nice improvement.
This should help ya a lot.
https://honda-tech.com/zerothread?id=1053318
and
http://www.geocities.com/cinq1....html
DaFredsta
Oct 18, 2009 01:31 AM
Ryan.
Oct 30, 2007 06:46 AM
trooper0641
25
Apr 25, 2004 05:44 PM
blackteg
Dec 31, 2003 02:20 PM
