multi port swap in a dual point car help please
Old Jun 25, 2007 | 11:58 AM
efsedan's Avatar
Default multi port swap in a dual point car help please
ok so i did a multi port single cam swap and i got a wiring harness made and my ecu keeps throwin the idle air control valve and the crank position code.... ive changed the idle air control and reset the ecu and my car still wont go pass 3200 rpms it just goes up to 3200 and stops it sounds like i have a studder box i cant figure it out so if u can help me le me kno
Old Jun 25, 2007 | 12:09 PM
wiZCo's Avatar
Stouts 'n' Scotch
The CPS code is what is causing it to stay in safe mode. The IACV code will just cause a bad idle. You do need to give a little more info:
What kind of car is this?
What motor & OBD?
What ECU?
Regardless, I'll guess that since you had a harness made instead of modifying the stock one , the problem lies in the wiring.
Old Jun 25, 2007 | 04:31 PM
george34's Avatar
Default Re: multi port swap in a dual point car help please (efsedan)
What do you mean by you got a wiring harness made(what did the person do to it)? Where did you get it from?
Old Jun 25, 2007 | 06:08 PM
efsedan's Avatar
Default Re: (wiZCo)
well the car is a 1989 honda civic obd0 1990 motor d16 and we modified the stock harness i jus dont understand the way its runnin cause those r the only 2 codes that it is throwin
Old Jun 25, 2007 | 06:21 PM
sikciv666's Avatar
Default Re: (efsedan)
my car was just doin that yesterday....i have a similliar set up (90 dx sedan + 91 ls swap) one of the wires i sodered, the tape fell off and was touching the mani...once i taped the soder..it fixed it right up.
still got a code 10 that wont leave my life...
Old Jun 26, 2007 | 02:42 AM
efsedan's Avatar
its a stock dual point harness modified to a multi port harness
Old Jun 26, 2007 | 04:57 AM
george34's Avatar
Did you switch the wires on the TPS in the correct order???
Old Jun 26, 2007 | 05:29 PM
efsedan's Avatar
Default Re: (george34)
im not real sure i had someone else wire it for me
Old Jun 26, 2007 | 05:56 PM
welfarepc's Avatar
why dont you take it back to the person who did it for you... they might actually know what they changed. double check everything he changed and make sure its correct
other then that, follow the haynes toubleshooting guide.. you do have a haynes dont you?
you might also wana check to see if the engine was throwing the CPS code before you installed it..
sevenfc
45
Oct 15, 2009 03:52 AM
DrewMD
Feb 22, 2007 11:34 AM
b18egdx
Aug 8, 2006 05:19 PM
EJ8CIVIC
Jan 10, 2006 09:21 PM
Axemurderer23
Jul 15, 2004 11:54 AM
