distrubitor burned!!
Old Jun 24, 2007 | 09:52 PM
ctam1986's Avatar
Default distrubitor burned!!
i'm in a process of buying this car which is a 96 ex. the owner show me the distributor with all of the wires burned out inside. now wat could this done to the harness or the car? thank you all
Old Jun 24, 2007 | 10:56 PM
SLO Sol's Avatar
Default Re: distrubitor burned!! (ctam1986)
I had the same problem last summer. The dealership said they had alot of problems with the z6 dizzys going bad. I went through 4 dizzys in 2 months
Old Jun 25, 2007 | 03:36 PM
ctam1986's Avatar
the owner said he tried another dizzy on but the car didn't turn on and he said it's not even crank or making any clicking sound. so what could that be? thank you every1
Old Jun 25, 2007 | 09:08 PM
SLO Sol's Avatar
Default Re: (ctam1986)
if it didnt crank or make a clicking noise that would prolly be the starter...
Old Jun 26, 2007 | 08:56 PM
slowcivic2k's Avatar
Default Re: (D-money 92si)
If a spark jumps the gap at the wrong time, it will arc to the nearest conductor, usually blowing a hole in the cap, it basically goes wherever the hell it wants. Happened to me with a B16A dizzy after the shaft bearing began to fail.
Old Jun 26, 2007 | 09:02 PM
hatchi's Avatar
check all fuses
Old Jun 27, 2007 | 12:01 AM
Default Re: distrubitor burned!! (hatchi)
Only suspect fuse would be the IGN fuse, check that just in case....
As for the no crank, make sure your S terminal connection is still plugged in solid, mine does that about every 5 months or so when the terminals begin to rust a bit, my car is really picky about it, and wont even power up. If you suspect the starter test it. Take a hot wire from the battery and touch it to the S terminal briefly, make sure your car is out of gear because this will crank the engine as well.
Old Jun 27, 2007 | 01:54 PM
ctam1986's Avatar
yeah thank you all
the fuse is the problem
Jeremy Harris
21
May 2, 2016 10:58 AM
DjBij099
Nov 9, 2008 11:45 AM
Romodavid15
21
Aug 21, 2008 10:07 PM
90Rexx
14
May 4, 2008 10:18 AM
96AcurategGSR
Jun 15, 2006 03:21 PM
