leveling out a warped flange???
Old Jun 24, 2007 | 07:37 PM
D-meet07's Avatar
Default leveling out a warped flange???
How thin can you go as far as milling down the header flange??? My sparks racing manifold was welded and braced and the dummies that did the job added to much heat to too long of a time period. 2 studs broke off due to warpage. I havn't lost any psi according to my boost gauge I just want to get it fixed. The good thing about the manifold is that it has a lip on the actual header flange so i might be able to save it. the lip is about 1/8 inch thick then you actually have the header flange itself.
The reason the manifold cracked in the 1st place was due to my broken tranny mount(which is fixed now). Im trying to do away with buying a new manifold for now.
thanx
Old Jun 25, 2007 | 12:46 PM
DaveF's Avatar
Default Re: leveling out a warped flange??? (D-meet07)
you can take it to a machine shop to have them mill it down, or you can try putting it on a belt sander to get it flat.
Old Jun 25, 2007 | 01:31 PM
D-meet07's Avatar
Default Re: leveling out a warped flange??? (dturbocivic)
yeah I know that much I wanted to know how thin can I go??? ^^
Old Jun 25, 2007 | 04:02 PM
9bells's Avatar
OG Fabricator
Hopefully it's 1/2" now, it's not mentioned in your post.
You could go down to 7/16 or maybe even 3/8. I know some guys use 3/8" stuff, so maybe.
I don't do many turbo manifolds, mostly n/a headers, so I'm not the definitive source here. I'm sure the other guys will chime in.
Good luck, hopefully you have a good machinist.
Old Jun 25, 2007 | 07:09 PM
HiProfile's Avatar
Default Re: leveling out a warped flange??? (9bells)
They don't have to take it to the next size down, this isn't like rethreading holes. They set it up on a mill with a big flycutter, then take off enough material so that its flat, 1/64th or 1/4th or whatever.
Old Jun 29, 2007 | 08:00 AM
D-meet07's Avatar
Default Re: leveling out a warped flange??? (HiProfile)
Thanx guys but how low can I go. Na is completly diffrent than turbo. I have the weight of the turbo not to mention that the manifold unlike na pressurizes..... I guess ill have to go for it. Im getting no help on the most helfull honda site.
Old Jun 29, 2007 | 01:12 PM
sharkytm's Avatar
I wouldn't go thinner than 3/8".
My log mani was all warped, almost 1/8", and luckily it was a 1/2" flange. They hooked it up to the head resurfacer, and took it down to 3/8", and its perfect.
Old Jun 29, 2007 | 04:04 PM
Howitt's Avatar
Default Re: (sharkytm)
Put it on the surface grinder and be done with it , only take off what you need.
Alternative is to put make a jig, put in the heat treat oven and get it toasty hot while bolted to the jig and it should even its self out then let it cool slowly
Old Jun 29, 2007 | 09:16 PM
D-meet07's Avatar
Default Re: (Howitt)
^Im very interested in this method. Please tell me more. Is that something a machine shop can do?? Or do I have to make my own jig. I have an old tymy oven in theback yard that I dont thing is getting any usage.
Old Jun 30, 2007 | 07:38 AM
dfoxengr's Avatar
Default Re: (D-meet07)
a house oven wont cut it, lol.
youd probably be fine as thin as 1/4" if it even needed it that much.
you can also bolt it up, run the motor hard, and then retorque it down, which could possibly fix it. do this a few times.
Old Jun 30, 2007 | 10:58 PM
90DALS's Avatar
i went down to 1/4" on my log. had no problems. as long as its flat, you fine
Old Jul 1, 2007 | 02:06 PM
D-meet07's Avatar
Default Re: (90DALS)
1/4 inch...woww!!!! Well I guess thats some good news. I beleive on my older prelude the turbo flange warped on it after getting it resurfaced to about 1/8. At the time I knew nothing about the material and durability of a manifold.
Old Jul 3, 2007 | 05:28 PM
D-meet07's Avatar
would an old 50-60 dollar belt sander do the job. I have alot more stuff to grind down.
Old Jul 4, 2007 | 12:36 AM
90dxhmt's Avatar
Side of the chop saw works for me
Old Jul 4, 2007 | 02:18 PM
D-meet07's Avatar
Default Re: leveling out a warped flange??? (90dxhmt)
the side of a chop saw will level out a thick header flange??? hmmmm how long did it take??
Old Jul 4, 2007 | 10:27 PM
90dxhmt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-meet07 &raquo;</TD></TR><TR><TD CLASS="quote">the side of a chop saw will level out a thick header flange??? hmmmm how long did it take??</TD></TR></TABLE>
It normally takes a a minute &gt; and will get the job done but i would recommend a better more accurate method, im just gettho so i use the chopsaw and have had success.For the amount of hassle a non sealing issue causes on a turbo car i would take it to a machine shop and get it cut then you know its good
Old Jul 7, 2007 | 02:36 PM
D-meet07's Avatar
I got it resurfaced at the local machine shop. It looks great. Only paid $35.00 bucks.
Havnt started it yet. Im finishing up my motor mounts.
Old Jul 7, 2007 | 05:41 PM
90dxhmt's Avatar
nice
Old Jul 8, 2007 | 01:35 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90dxhmt &raquo;</TD></TR><TR><TD CLASS="quote">Side of the chop saw works for me </TD></TR></TABLE>
Talk about a death trap waiting to happen.
Old Jul 9, 2007 | 05:55 AM
Howitt's Avatar
Default Re: leveling out a warped flange??? (RCautoworks)
Holy **** Im marking it on my calander someone on hondatech actually listened to me. $35 seems quite reasonable to have it surfaced
Old Jul 9, 2007 | 07:47 PM
D-meet07's Avatar
Default Re: leveling out a warped flange??? (Howitt)
yeahhhhhh boyyyyyy...
Old Jul 11, 2007 | 07:57 PM
meanEG's Avatar
i used a striaght edge and a press to get mine close and took a minimal amount off in a head resurfacer, big belt sander
gehlSRT
Welding / Fabrication
Oct 11, 2011 09:34 AM
808DB1
Feb 22, 2008 05:04 PM
luv2drivecrx
Oct 23, 2005 08:03 AM
luv2drivecrx
Oct 19, 2005 02:14 AM
kickz
Aug 4, 2002 09:28 PM
