Is it burning oil?
depends on WHY its running rich in the first place. if its due to o2 sensor, you should replace the o2. if its ignition problem where its not igniting your fuel right, fix your ignition problem. if its larger injectors, get it tuned. etc etc etc etc
o ok ok.....i did have my check engine light on and it was reading o2 sensor but then after about 3-4 days it reset and the check engine light went off. so it might b the o2. but y would the computer reset wit out me reseting it by hand
I have the same issue with my car. The car was re-built but I did not know there was extensive work to be done.
P&P head and stock block that was rebuilt. The car burns about a quart every 900 miles or so.. There is noticeable black carbon/oil deposits shooting out of the exhaust and stuck on the back of my car.
Would that be because oil is passing through the engine due to egg shaped cylinder walls?
Sorry to jack the thread, having some issues as well....
BUMP!!!
BUMP!!!
