1998 Accord EX Auto - NO SPEEDOMETER??
Old Jun 23, 2007 | 11:05 PM
BoostdRex's Avatar
Default 1998 Accord EX Auto - NO SPEEDOMETER??
Is there a way to test the VSS before buying a new one? I thought I saw somewhere that it can be tested with a volt meter. Anyone hear of this before? I wanna test it before assuming it's the ECU, because I've already swapped out the speedo cluster with another working speedo cluster I had and it's not that. So my guess is that it's the VSS.
Any tips would be helpful.
Thanks!
Old Jul 31, 2007 | 08:32 PM
BoostdRex's Avatar
Default Re: 1998 Accord EX Auto - NO SPEEDOMETER?? (BoostdRex)
BUMP - ANYONE??
Old Aug 1, 2007 | 11:20 PM
kbud's Avatar
I've read on here to try using the Cruise Control. If it works, the VSS should be ok and the problem will be with the speedometer itself. My understanding is that they are on two separate circuits, both using the VSS, not one feeding the other.
Old Aug 1, 2007 | 11:26 PM
BoostdRex's Avatar
Default Re: 1998 Accord EX Auto - NO SPEEDOMETER?? (kbud)
The cruise control does not work.... And I bought a new cluster thinking it was the cluster and it wasn't - same results...
Old Aug 2, 2007 | 07:39 AM
H2290's Avatar
If the cruise, speedo, and tach are dead it is the VSS. There are three wires going to the VSS. One should be ground, one should be 5v and would should fluctuate voltage up and down as you spin a wheel that is jacked up off the ground.
Old Aug 2, 2007 | 07:48 AM
BoostdRex's Avatar
Default Re: 1998 Accord EX Auto - NO SPEEDOMETER?? (H2290)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2290 &raquo;</TD></TR><TR><TD CLASS="quote">If the cruise, speedo, and tach are dead it is the VSS. There are three wires going to the VSS. One should be ground, one should be 5v and would should fluctuate voltage up and down as you spin a wheel that is jacked up off the ground.</TD></TR></TABLE>
But the tach works tho... So if the tach works but the cruise and speedo do not, could it be my ECU?
Old Aug 2, 2007 | 07:49 AM
awdgsx96's Avatar
When you put in the new speedo cluster did you make sure the 4 back bolts were very tight? And that all harnesses will plugged back in i.e. dimmer, hazards, cruise?
Old Aug 2, 2007 | 07:57 AM
BoostdRex's Avatar
Default Re: 1998 Accord EX Auto - NO SPEEDOMETER?? (awdgsx96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdgsx96 &raquo;</TD></TR><TR><TD CLASS="quote">When you put in the new speedo cluster did you make sure the 4 back bolts were very tight? And that all harnesses will plugged back in i.e. dimmer, hazards, cruise?</TD></TR></TABLE>
Absolutely...
Grr, I am so confused... Someone mentioned ECU but I was unsure because a supposed Honda tech who works at the local Honda dealership said that if anything was wrong with my ECU at all, tht the car wouldn't run...? I am beginning to doubt that if the symptoms of a dead VSS doesn't add up...
Old Aug 2, 2007 | 08:34 AM
TheMuffinMan's Avatar
He knows where you live!
VSS problem = no cruise, no speedo (or intermittant) , and CEL
Cluster problem = cruise, no speedo, no CEL
Old Aug 2, 2007 | 08:37 AM
H2290's Avatar
Default Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">VSS problem = no cruise, no speedo (or intermittant) , and CEL
Cluster problem = cruise, no speedo, no CEL</TD></TR></TABLE>
Right-o. Is there a CEL with VSS code?
Old Aug 2, 2007 | 08:39 AM
BoostdRex's Avatar
CEL on?
Here is what is wierd:
No cruise, no speedo and the only CEL code it's throwing is the o2 sensor that I know I needed to replace prior to this issue. That's it....
Old Aug 2, 2007 | 08:43 AM
when did you last check it?
reset the cel (pull the battery) and see if a new one pops up and check that one
Old Aug 2, 2007 | 10:57 AM
BoostdRex's Avatar
K...
Old Nov 5, 2007 | 11:01 AM
abeaujuin's Avatar
Default Re: (BoostdRex)
I am currently having the same problem.
I just replaced the VSS and this did not fix it
I just replaced the Speedometer gauge still doesn't work.
I unplug the battery for a few the check engine light goes away but when driving the Speedometer does not move and the check engine light comes right back on.
Not sure what else to change this is a 1998 Honda Accord EX.
Any other suggestions?
Old Nov 5, 2007 | 11:26 AM
Does cruise control work?
Did you replace the VSS with a good , known working one?
Drola
Sep 14, 2011 07:26 AM
ShelbyX3
Apr 4, 2008 09:53 AM
civicDX2178
May 3, 2006 06:43 AM
mc
Apr 19, 2004 07:58 PM
