question about a throttle cable. 95 gsr motor in a 97 ek
Old Jun 21, 2007 | 12:20 PM
ebrakeracin4's Avatar
Default question about a throttle cable. 95 gsr motor in a 97 ek
What throttle cable do i use? I have a 95 gsr swap with stock intake manifold in a 97 civic ex coupe. I have tried a 95 gsr cable and the actual metal cable was too long. same with the stock one and a 95 integra ls. PLease help! I need to finish this car asap!
Old Jun 21, 2007 | 12:35 PM
Xscort's Avatar
dont know why the gsr cable isnt working. should work, u supposed 2 correspond the cables to the swap>> LS cable for LS swap, gsr for gsr
Old Jun 21, 2007 | 12:44 PM
redsled00's Avatar
Default Re: question about a throttle cable. 95 gsr motor in a 97 ek (ebrakeracin4)
You may have to use an extension for the throttle cable bracket. Get a piece of metal about 2 inches long and drill three holes in it. Use the throttle cable bracket holes for the template.
Old Jun 25, 2007 | 01:00 PM
Default Re: question about a throttle cable. 95 gsr motor in a 97 ek (redsled00)
i made a bracket that pushed the throttle bracket away from the throttle rotor. It works great. Thanks for the replies!
teamXteg
May 19, 2014 04:11 PM
import-tooner
Jan 25, 2011 05:30 AM
gapergurlie_18
Oct 23, 2008 05:22 PM
123Four
Sep 12, 2007 03:08 PM
hondaitegra
Apr 20, 2003 01:20 PM
