PAINT
Old Jun 20, 2007 | 03:33 PM
Exploziveaf1's Avatar
Default PAINT
ok i tinted my tail light and got over spray, i wet sanded with 2000 grit sand paper. and it took out the clear didnt look like it when it was wet but it dried and it showd, what next car is blue, and clear had the activator? get it re cleared or can i buff it out?
Old Jun 20, 2007 | 04:18 PM
kevin0405's Avatar
Default Re: PAINT (Exploziveaf1)
as long as you didnt sand through the clear it will buff out. just be careful buffing and not get it too hot and burn the paint.
Old Jun 20, 2007 | 05:13 PM
well when i wet sanded the paint still looked like it should, but when it dried it was dull and ****, but wet again and look normal that through the clear?
Old Jun 20, 2007 | 07:11 PM
kevin0405's Avatar
when you sand the clear, it will look dull. you buff it to bring the gloss back out
Old Jun 20, 2007 | 07:44 PM
mike9571's Avatar
Default Re: PAINT (kevin0405)
When you sanded it was it the water white or the color of you car? If it was white than your ok, if not and it was the color of the paint you went through.
Old Jun 21, 2007 | 10:29 AM
Water white, I got it fixed, here is what i did, I went to my local paint store and got 1500 grit sand paper. Some 3M rubbing compound, $24 something for a huge bottle. Also picked up a bottle of spray wax. Any wax will do, I already had a 12 Inch buffer. Ok Step 1.) Wet sand the area or whole car, let it dry 2 see any sports missed, then go back and do those. Not pressing 2 hard let it float over with a little pressure, don't go into the paint u get a new paint job.
2.) Put the rubbing compound on the are of attention, Note: only do one section at a time, don't try it all at once, Continue to detail until u think its ready, or until compound dry to a harden state.
4.) wipe excess off with towel
5.) spray on wax and buff than in until harden state as well.
6.) wipe off with towel
7.) wash excess compound wax off trim ext, use a towel of flannel cloth.
I did this because i got over spray from tinting my tail lights on it, for retards SPRAY PAINT ON CAR!
PM me if theres anything i have missed sorry no pics will try 2 get them later
pfdsc7
Aug 22, 2013 12:39 PM
Armorzaku
Paint and Body
Mar 18, 2009 08:14 PM
m00sie
Mar 21, 2007 03:14 PM
cilvia
Nov 11, 2006 11:34 AM
xcellorator
Apr 26, 2005 03:37 AM
