Painting question
Old Mar 17, 2009 | 08:11 PM
Armorzaku's Avatar
Default Painting question
If i wanted to paint my car myself, sand it down like no other and paint it myself what would i have to buy/do?
not a spray paint job, like a good paint job, i have a white car but the paint has definitely seen better days.
i want to paint it white again.
Old Mar 17, 2009 | 08:19 PM
itotech's Avatar
Default Re: Painting question
Ok there's defenetly a paint section in Honda-Tech for this.Shu over there
Old Mar 17, 2009 | 09:32 PM
jonvo's Avatar
the things you will need are:
1. sandpaper
2. sanding block
3. bondo
4. primer
5. paint- base coats, clear coat, activator, reducer
6. a spray gun
7. air compressor
8. masking tape
9. masking paper
10. tact cloth
11. rubbing alcohol
steps:
1. sand the car down and the the body straight with bondo
2. mask off car
3. wipe down with alcohol
4. primer it
5. wet sand it with about 400-600 grit
6. shoot the basecoat
7. shoot clear coat
8. color sand
9. buff/polish
This is basically what you need to do, but of course these are very vague instructions. There are a lot of other little things you need to know and should research before attempting to paint your car. It isn't an easy job.
Old Mar 17, 2009 | 09:47 PM
jhammond_82's Avatar
Reject Papi
in my sig i have a build thread. check that out. and as for supplies, the gentleman above me has it down pretty good. i would recommend using like an 80 grit. then a 180, then a 320 to finish it off. but the quality of the job you get depends on how much time you want and have to put in it.
Old Mar 18, 2009 | 08:10 PM
jdmjoka's Avatar
DB squad #282
Just curious why this thread don't get locked but the one with "acura integra usdm to jdm front" thread get's locked when that actually has something to do with "acura integra"! just a simple question.
Old Mar 18, 2009 | 08:14 PM
CPreston's Avatar
its not really necessary to wet sand the primer, sand yes but you dont need to wet sand.
moxi
Oct 21, 2011 03:26 PM
lilbill_ed8
Paint and Body
May 28, 2008 06:45 PM
WarpFactorVIII
Paint and Body
Sep 5, 2007 10:55 AM
awalp
Nov 13, 2006 07:01 PM
bboyprelude
Jun 2, 2003 02:54 PM
