Rear Sway Bar Bracket.... BROKEN ....How should I go about fixing?
Old Jun 20, 2007 | 09:00 AM
iH8RICERZ's Avatar
Default Rear Sway Bar Bracket.... BROKEN ....How should I go about fixing?
Well, a week ago, I started hearing a lot of noise coming from the rear passenger side of my 94 GSR. I knew it was suspension related since it only made a lot of noise when I was going sideways up or down driveways. See pics below from what I found when I jacked up my car:
So my question is, what are my options and how do I go about fixing this? I was thinking about bringing it some where to have a small plate of metal welded to cover the hole, then drill it out where the bolt should go, then get an asr brace with the itr rear sway bar and beaks kit.... This sucks.... Any suggestions?
Old Jun 20, 2007 | 09:17 AM
grtek's Avatar
Default Re: Rear Sway Bar Bracket.... BROKEN ....How should I go about fixing? (iH8RICERZ)
Damn dude that sucks, I saw someone on here with the a similar situation, he had it welded like you were thinking and then the asr brace. Hope it don't cost you too much man, I wanna see that new engine in place this summer!
Old Jun 20, 2007 | 10:18 AM
YAH YAH's Avatar
now that is exactly why u get a reinforcement kit.
Old Jun 20, 2007 | 10:22 AM
KoalaEatingTree's Avatar
Default Re: Rear Sway Bar Bracket.... BROKEN ....How should I go about fixing? (chiboi800)
I think you are on the right track. Have a plate welded over the entire opening and a new hole drilled to receive the bolt. Are you replacing the cracked bracket?
Old Jun 20, 2007 | 10:26 AM
iH8RICERZ's Avatar
Default Re: Rear Sway Bar Bracket.... BROKEN ....How should I go about fixing? (KoalaEatingTree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoalaEatingTree &raquo;</TD></TR><TR><TD CLASS="quote">I think you are on the right track. Have a plate welded over the entire opening and a new hole drilled to receive the bolt. Are you replacing the cracked bracket?</TD></TR></TABLE>
I might just end up ditching this sway bar (i believe its made by neuspeed.....came on the car when I bought it).....but if I can fix the hole, then I'll probably just end up getting the asr brace + jdm itr rear sway. crossing my fingers....
Old Jun 20, 2007 | 10:44 AM
jomama's Avatar
good luck with the fix... i'd do what you said
jvue
May 28, 2013 09:19 AM
rickscrx
Dec 19, 2011 05:08 AM
ekinshuya
10
Jun 18, 2009 11:11 PM
iH8RICERZ
Suspension & Brakes
25
Aug 17, 2007 04:33 PM
RAK
Sep 24, 2005 07:34 PM
