CRX problems
Old Jun 18, 2007 | 10:11 AM
silversohc87's Avatar
Default CRX problems
my CRX is bogging out why i drive so i need some help I can't seem to find the problem out I cleaned out the throttle body and i dont wut i could be if you might know how to fix it let me know asap
Old Jun 18, 2007 | 10:15 AM
team-savage's Avatar
is your check engine light on? you need to describe the problem a bit better.
Old Jun 18, 2007 | 10:18 AM
SloazzEKhatch's Avatar
If it is bogging on the throttle and not at idle it is probably the timing. A friend of mine had a timing belt jump and tooth and had the same problem.
Old Jun 18, 2007 | 10:19 AM
Default Re: (team-savage)
well the check engine light has been on because of the swap. the problem is when I'am driving and giving gas the car is like boggin out or delaying accerlating. and the only way of keeping it from boggin out is to pop the clutch and give it more gas
Old Jun 18, 2007 | 10:20 AM
HBK's Avatar
HBK
Default Re: CRX problems (silversohc87)
Basic mechanics.
1. Do a tune-up
Why? Well why not? It'll be good for your car and could solve your problem.
- Fuel Filter
- Cap/rotor
- plugs/wires
- oil/oil filter
- tranny oil
2. You can adjust your throttle body for quicker throttle response. That might help.
3. You can run some Seafoam in your gas tank, oil, and vacuum lines. That'll kill out some built up **** in your engine and will smoke out of your exhaust.
4. You could be running rich. Get a fuel pressure regulator and tune it down.
Old Jun 18, 2007 | 10:21 AM
yeah iam running rich good looking forgot that i was running rich lol
Old Jun 18, 2007 | 10:31 AM
HBK's Avatar
HBK
Default Re: (silversohc87)
What engine/ecu are you using?
Old Jun 18, 2007 | 10:34 AM
hondacivic90zc's Avatar
Default Re: (HBK)
well running rich can also be contributed to the timing, i am not saying this is for sure the problem but it is a possibility because my sohc zc swap was running rich for the past two months until i noticed that the timing belt was off two teeth advanced. I must say though it was responsive as hell.
Old Jun 18, 2007 | 04:28 PM
Default Re: (iandavis90)
b16a1 not to sure of the ECU
elnene_14
Aug 25, 2013 10:55 AM
ymibuyingmore
Jun 12, 2011 06:08 PM
Mohamad
Honda S2000
11
Aug 27, 2008 02:21 PM
imnike9000
Apr 20, 2008 01:30 PM
roughrydin89
May 18, 2003 12:33 AM
