Honda S2000 Honda S2000
Throttle problem
Old Aug 26, 2008 | 01:42 PM
Mohamad's Avatar
Default Throttle problem
Hello Guys, I have a throttle problem in my 2004 AP1,yes AP1 because it's a Euro version, still come with an F20C engine until this day but with the new generation body and everything. Anyway, the problem is that, after 5-10 minutes or so of driving, I get a weird feel of lack of gaz getting pumped into the engine as if the car is about to turn off, or like a trash in the gaz, then I pump the throttle a little, it goes away, and everything goes back to fine and smooth?!??!? This happens almost every 5 min for like couple of seconds. I'm sure it's not gaz type or gaz quality, I've tried different stations, and still the problem exists, and not consistent that's the weird thing. No Engine Check light is on.
My car has 55,000 Km on it now. that's like 34k miles.
Any idea?
Old Aug 26, 2008 | 06:59 PM
Black S2K's Avatar
first off look at ur vin its an ap2 even though its still got the f20 in it.
second try using an injector cleaner. or maybe do the map wack thers a diy on s2ki.
Old Aug 27, 2008 | 06:34 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Throttle problem (Mohamad)
Change you spark plugs and report back
Old Aug 27, 2008 | 07:34 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: Throttle problem (White Smoke)
map whack
Old Aug 27, 2008 | 08:03 AM
chimmike's Avatar
before doing any of that, get the CODE READ!
Old Aug 27, 2008 | 08:25 AM
Mohamad's Avatar
I changed my spark plugs, I am putting a cleaner every time I fill up gaz. The problem still exist, I'm tyring to see if anyone of you guys got such a problem before I go for the checkup.
My VIN is this: JHMAP11304T200453
AP1 and AP2 represents the engine, and since Euro version S2000 comes with an F20C, they still call it AP1, even the 2008 model.
Old Aug 27, 2008 | 08:39 AM
i my honda
Global Mod
Default Re: (Mohamad)
You have a CEL???
AP1 and AP2 represents the chassis code not the engine code, which is F22.
Old Aug 27, 2008 | 10:27 AM
Mohamad's Avatar
White Smoke. Check your info. Euro S2000 VINs are still called AP1 even 2008 model with the new 2004+ body look, AP1 in this case (S2000) is representing the Engine. Only in US, AP2 is the new look and new engine 2004+
Anyway it's not the topic we are discussing.
CEL is NOT on.
Old Aug 27, 2008 | 10:47 AM
chimmike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohamad &raquo;</TD></TR><TR><TD CLASS="quote">
CEL is NOT on. </TD></TR></TABLE>
make up your mind dude, in your very first post, you said it WAS on.
Old Aug 27, 2008 | 10:56 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohamad 1st Post &raquo;</TD></TR><TR><TD CLASS="quote">No Engine Check light is on.</TD></TR></TABLE>
Old Aug 27, 2008 | 11:27 AM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">
make up your mind dude, in your very first post, you said it WAS on. </TD></TR></TABLE>
map whack
Old Aug 27, 2008 | 02:21 PM
Mohamad's Avatar
chimmike:
"and not consistent that's the weird thing. No Engine Check light is on."
I said in the very first port "No Engine Check light is on"
tigerwing
Jul 23, 2014 10:25 AM
UKintegra
Jun 8, 2011 12:32 PM
ITR010342
Acura TSX
Jun 23, 2010 08:45 AM
Jeef
May 3, 2005 07:01 AM
