breather/catchcan question
Old Jun 16, 2007 | 07:55 PM
slambedcivic's Avatar
Default breather/catchcan question
Alright so this is an old OBD1 block.
Im going to be running a catch can. Ive taken all of my breather stuff out and if im correct I am supposed to convert #1 to a nipple to run to my catch can. #2 gets plugges with a threaded plug, and #3 gets a freeze plug pressed into it. Right?
And also, this is an OBD1 block and Im running an OBD2 valve cover. Is there any special or fancy way for me to block off the PCV hole in the VC?
thanks in advance
Old Jun 16, 2007 | 09:28 PM
sauceja's Avatar
Default Re: breather/catchcan question (slambedcivic)
https://honda-tech.com/zerothread?id=1939677
About half way down you can see how I am running mine.
I heard that your number 1 isn't the best place to run a line.
I blocked off #3 with a thing from Napa. I believe that opening is 32mm??? maybe 34?
I will run a 1/2 hose from one line to the catch can and the #2 you have I will run a 3/8 hose to the catch can but T'd into it from the valve cover with a one-way valve kinda like the oem check valves or pcv valves but different.
Hope that helps you.
incubusboy87
Aug 13, 2007 09:02 PM
slambedcivic
Jun 19, 2007 06:27 AM
93egallmotor
Apr 21, 2007 01:45 PM
912
Feb 12, 2006 05:27 PM
