91 Civic SI, Ckeck valve location??
Old Jun 16, 2007 | 10:48 AM
sirtef9's Avatar
Default 91 Civic SI, Ckeck valve location??
Where is the best place for my missing link?front of the map or bottom or back port?
thanks
Old Jun 16, 2007 | 10:51 AM
mr.speaker's Avatar
Default Re: 91 Civic SI, Ckeck valve location?? (sirtef9)
install the check valves between the map sensor and intake manifold vacuum line...
By the way,it's 2007..I did this **** in 99 and hated it but didnt have a choice really.
Old Jun 16, 2007 | 10:52 AM
sirtef9's Avatar
Default Re: 91 Civic SI, Ckeck valve location?? (mr.speaker)
the vacuum port on the back of the manifold? i have 2 check valves there now, when I roll into boost hard into 3rd I get the got DAmmmm Map code. Was curious if I had them in the wrong spot
Old Jun 16, 2007 | 10:55 AM
mr.speaker's Avatar
it doesnt really matter which one,as long as its between the intake manifold and map sensor ..
how many lbs of boost is your setup at? you may need another check valve
Old Jun 16, 2007 | 10:56 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">it doesnt really matter which one,,as long as its between the intake manifold and map sensor ..
how many lbs of boost is your setup at?</TD></TR></TABLE> real quick is this the same Mr. Speaker from a couple months back???
and to the OP it doesn't matter about the direction of connection, 3 check valves should do it though
mr.speaker's Avatar
Default Re: 91 Civic SI, Ckeck valve location?? (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote"> real quick is this the same Mr. Speaker from a couple months back???</TD></TR></TABLE>
yes.
Old Jun 16, 2007 | 11:28 AM
sirtef9's Avatar
5lbs , I have a missing link too, should I use that or the 3 check valves?
Old Jun 16, 2007 | 12:38 PM
mr.speaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirtef9 &raquo;</TD></TR><TR><TD CLASS="quote">5lbs , I have a missing link too, should I use that or the 3 check valves?</TD></TR></TABLE>
no,just use a 3rd check valve.
Old Jun 17, 2007 | 09:26 AM
sirtef9's Avatar
thanks you:-)
99hondacura
Mar 28, 2008 11:39 AM
mike93boost
Jun 19, 2006 05:43 PM
88 rex
Aug 16, 2005 06:49 PM
OVERBOOST TEG
Oct 30, 2003 10:49 AM
