what clutch and axles? ( h2b )
what clutch and axles are stong enough for an h2b build?i dought ill have more then 250 hp to the wheels but i want a clutch and axles that will hold up to high rpm launches on slicks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorRandy »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>is that flywheel for sale?if it is,then how much does it way and what do you want for it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 »</TD></TR><TR><TD CLASS="quote">I i dont know how much of a difference a different brand of flywheel could make...</TD></TR></TABLE>niether do i,thats why i didnt ask about a flywheel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 »</TD></TR><TR><TD CLASS="quote">I like my ACT xtss clutch, so I would recommend act.
As for the flywheel, i have a fidanza, i dont know how much of a difference a different brand of flywheel could make...</TD></TR></TABLE>
Well if you look closer to the 2nd picture i posted.... you'll notice that the center protrudes out more..... thats to compensate for the h2b mounting plate. This means that you will not have to use the flywheel spacer or the extended bolts provided with the kit.
NO SPACER + STOCK FLYWHEEL BOLTS = ZERO PROBLEMS
Contact Luis @ Clutch Masters if you have anymore questions. This flywheel Is available for a twin disc or standard pressure plates.
as far as the axles...i wanna say that factory b series will hold up to 240 ft lbs of torque but don't quote me on it...thats what i'm using on mine. and i'm getting an act clutch this week!!! H2Bs RULE!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorRandy »</TD></TR><TR><TD CLASS="quote">Well if you look closer to the 2nd picture i posted.... you'll notice that the center protrudes out more..... thats to compensate for the h2b mounting plate. This means that you will not have to use the flywheel spacer or the extended bolts provided with the kit.
Are they having problems with the longer bolts?
</TD></TR></TABLE>Are they having problems with the longer bolts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel »</TD></TR><TR><TD CLASS="quote">
Are they having problems with the longer bolts?</TD></TR></TABLE>
no there has not been any issues.
vectorsolid
Oct 3, 2008 01:19 AM
maxspeedhonda
Jan 31, 2005 08:17 PM
