will a OBD2 JDM VTEC solenoid work on a USDM OBD2 Motor & ECU?
Old Jun 15, 2007 | 06:41 PM
Vero's Avatar
Default will a OBD2 JDM VTEC solenoid work on a USDM OBD2 Motor & ECU?
I have a USDM B16 motor which is OBD2. I need to get a VTEC soloenoid and I have found one that from a JDM OBD2 motor.
Will this work on the USDM motor with the stock EM1 or ITR Ecu?
Old Jun 16, 2007 | 08:19 AM
Vero's Avatar
Default Re: will a OBD2 JDM VTEC solenoid work on a USDM OBD2 Motor & ECU? (Vero)
Nobody knows?
I know most JDM ECU's will work just fine, but anyone know if the JDM ECU will work for US emissions?
Old Jun 16, 2007 | 12:39 PM
Bense's Avatar
theres two wires that you gotta jump on the ecu, ii forget which ones they are. or you could use the pressure switch from another vtec solenoid. whatever you wanna do!
Old Jun 16, 2007 | 03:41 PM
Vero's Avatar
Default Re: (Bense)
is that on the USDM ECU you have to jump?
ek9eli
Feb 5, 2014 09:22 PM
phoxking
Mar 25, 2011 12:04 PM
Vero
Jun 28, 2007 04:48 PM
totaled
Aug 24, 2003 07:47 PM
silvershiny-ek
May 15, 2003 08:00 AM
