custom intake box
Old Jun 15, 2007 | 10:54 AM
BIGblock97's Avatar
Default custom intake box
i am looking to make a custom fab aluminum intake box to put in my engine bay and around my air filter so no water gets sucked up...it is a 3inch short ram intake, anyone have any ideas? thanks
Old Jun 18, 2007 | 11:39 AM
kommon_sense's Avatar
Default Re: custom intake box (BIGblock97)
take a look at the comptech ice box. Its a good and fairly straight forward design.
Old Jun 25, 2007 | 03:28 AM
BIGblock97's Avatar
im kinda looking to see if anyone has any custom setups?
Old Jun 25, 2007 | 12:25 PM
deryck324's Avatar
yo im not trin to gice you **** or nothin but you should search first
https://honda-tech.com/zerothread?id=1942925
Old Jun 25, 2007 | 11:05 PM
.1type.'s Avatar
Default Re: (deryck324)
my setup my buddy made for me...
another pic of it in my old car...
Old Jun 26, 2007 | 03:05 AM
stillrockin18s's Avatar
Heres a couple shots of mine I made out of metal tubing and fiberglass
Old Jun 26, 2007 | 12:06 PM
victorpapa's Avatar
Default Re: (stillrockin18s)
Here it is (installed on the car of a friend) my custom airbox named VP2 with internal big velocity stack
and here it is the variable flow version ( you can set the air flow according to your mods)
completely open air flow
completely closed air flow
Old Jun 27, 2007 | 04:37 AM
Andrew Marquis's Avatar
^ woah! ^
nice!
Old Jun 27, 2007 | 05:50 AM
91jdmhatchback's Avatar
Default Re: (Andrew Marquis)
please can you explain your design a little better. and how this will help
Old Jun 27, 2007 | 12:35 PM
BIGblock97's Avatar
Default Re: (91jdmhatchback)
thanks for all the pics they are all close to my idea...im probably going to have to draw something up and then design it...
Old Jun 27, 2007 | 01:11 PM
victorpapa's Avatar
Default Re: (BIGblock97)
Yes of course Matt. Let’s say that VP2 is an airbox chacterised by a large volume of air (about 10 liters) already
filtered and therefore immediately suitable for being injected into the engine. Inside the cylinder you will find a special alluminum stack finalised to increase air pressure and air velocity. Laterally a heating barrier prevents the sucking of warm air coming from the engine. The efficiency of the system compared with others AB just comes from its big volume and the fact that the internal airflow meets no further obstacle before the injection, eccept the throttle. Several dyno tests have been made compearing VP2 and Mugen AB which showed a prevalence of the first one in terms of horsepower and torque. As for the Variable VP2 this represents an evolution which further improve VP2 efficiency mainly to adapt airflow to the set up of different cars as well as the trackrace characteristics.
Old Jun 27, 2007 | 02:44 PM
corrupt0r's Avatar
any pics of the internals?
Old Jul 1, 2007 | 03:49 PM
honda400ex's Avatar
Default Re: (corrupt0r)
thats a huge bitch!
Old Jul 1, 2007 | 09:39 PM
DaZDiLI's Avatar
BTW, Would it be better to have the front open or the whole filter covered?
Zaraki
50
Jun 13, 2013 04:13 PM
dmckrazy45
Jun 13, 2005 07:52 PM
#26Type-R
Apr 16, 2004 12:29 AM
CRexcellence
Sep 13, 2002 08:19 AM
LillDragun
Sep 2, 2002 10:15 PM
