brake oil keeps running low
if you dont see any visable leaks on or around the lines or near the wheel cylinders then it most likly is your master cylinder leaking into the brake booster and may be leaking into you engine through the vaccum lines. have you noticed the car running any differently?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by placid888 »</TD></TR><TR><TD CLASS="quote">check the brake pedal under the dash</TD></TR></TABLE>
what should i check it for?! leaks?! lose?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 »</TD></TR><TR><TD CLASS="quote">
what should i check it for?! leaks?! lose?</TD></TR></TABLE>
It's not rocket science, if you are losing fluid, it's going somewhere. Find it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrTurboCRX88 »</TD></TR><TR><TD CLASS="quote">how does the pedal feel. if it is leaking that much, you would definatly feel it in the pedal</TD></TR></TABLE>
actally nothing is different, i guess its leaking inside the vacume line, the brake is perfect never felt anything wrong with it, even with the brake fluid light is on, i just add a new fluid and keep going
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil »</TD></TR><TR><TD CLASS="quote">What the hell is brake oil? You smell burning oil? What's going on here?
Does your car have rear drum brakes? If so, I bet your wheel cylinders took a ****.</TD></TR></TABLE>
Maybe that is what they call it in that part of the world. Not everyone has the same terminology but thanks for playing a fool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">
Maybe that is what they call it in that part of the world. Not everyone has the same terminology but thanks for playing a fool. </TD></TR></TABLE>X2
I say just pump the crap out of them while it's parked. After a minute of pumping hop out and crawl underneath. If it's leaking you'll see a puddle somewhere. After you find the puddle...look up.
It's what I'm best at. A little googling, I am wrong. Brake oil for every one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 »</TD></TR><TR><TD CLASS="quote">X2</TD></TR></TABLE>
Good for you! Pop that collar!
Good for you! Pop that collar! </TD></TR></TABLE>
well your signature says it all...pop your collar to then while you think you are overly sleeping with women...only a gay guy would say that!!!the end
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil »</TD></TR><TR><TD CLASS="quote">It's what I'm best at. A little googling, I am wrong. Brake oil for every one...Good for you! Pop that collar! </TD></TR></TABLE>
hahahahha, **** off the moderator bro
put his *** back on trial mode Toad
