Mini Me Help?
Old Jun 15, 2007 | 05:40 AM
civicracer59's Avatar
Default Mini Me Help?
I know i saw it on here before but i searched and cant find anything. What is the difference when doing a mini me on a 92 cx? I think it has something to do with the wiring but not sure. Any help? Thanks
Old Jun 15, 2007 | 05:46 AM
97Ej6mike's Avatar
Default Re: Mini Me Help? (civicracer59)
It will require the VTEC head (obviously). Also an ECU that has vtec, for your Cx that would probably mean a p28 (obd1 + vtec). Make sure its a 5spd ecu too(or automatic if you cars auto) . Also, since VTEC isnt in the Cx Wiring harness, you can either invest in any 92-95 ex\si wiring harness (easiet way) that has the VTEC plugs already in it, or wire it up yourself.
Also, since you have the CX, you also have the longest gears in any SOHC tranny. I would think about looking for a z6 tranny, of any 92-95 Ex or Si, it would benefit you greatly.
Old Jun 15, 2007 | 05:51 AM
Default Re: Mini Me Help? (97Ej6mike)
I thought i read on here somewhere thatt he 92's were already wired for vtec? I might have just misread something though. N yeah i know the tranny really sucks. Thats def. my next investment.
Old Jun 15, 2007 | 08:30 AM
VTEC IS UR BEST FRIEND's Avatar
92's maybe wired for vtec in the engine bay but still need to be wired to the ecu. I dont know tho...
Old Jun 15, 2007 | 09:50 AM
Default Re: Mini Me Help? (VTEC IS UR BEST FRIEND)
I just need to know whether or not I need to get a different harness or if the 92 cx is pre wired for vtec? If it is not how can i wire it into my existing harness? I know that it will need wired into the ecu. Thanks for the input though.
Old Jun 15, 2007 | 11:00 AM
ddd4114's Avatar
Don't you have an 8 valve engine? And you're going to swap a 16 valve head on it?
Old Jun 15, 2007 | 04:05 PM
Default Re: Mini Me Help? (ddd4114)
The valves are in the head not the block. So im taking my 8 valve head off and putting a 16 vavle head on. All I need to know is how to wire the vtec into my 92 cx? Im almost positive that there is a major wiring difference in the wiring of a 92 mini me swap. Anybody?
Old Jun 15, 2007 | 04:14 PM
search noob
https://honda-tech.com/zero...14432
Old Jun 15, 2007 | 04:51 PM
HondaPartsHero's Avatar
Technical Hero
just get an EX/Si engine harness, the 92's are wired for VTEC to the ECU as well so it'll be plug and play with a P28, if you go the D16Z6 way
Old Jun 15, 2007 | 07:41 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicracer59 &raquo;</TD></TR><TR><TD CLASS="quote">The valves are in the head not the block.</TD></TR></TABLE>
But the valve reliefs are in the pistons, which are in the block. I know a few b8's have 16 valve reliefs, but make sure yours is one of them. Otherwise, you're going to be very disappointed when you pull your head.
fv8s
Mar 1, 2010 06:07 PM
JDM_Frijoles
Jun 16, 2006 05:18 PM
northkai3
Jun 5, 2005 10:47 PM
1sick4door
Jan 21, 2002 11:07 AM
