sohc swap ???
sohc swap ???
i have a 92 cx and about to install a 95 ex longblock....longblock is complete...i was just gonna reuse my cx tranny....as i was told everything should just mount up..axles and everything from my x should work fine right??..only problem im having is with the wiring...im guessing there should be only the vtec that is different right??..how would i wire that up??..the rest of the stufshouldjust plug up to my cx wiring harness rigt??
Re: sohc swap ??? (1sick4door)
to make the swap easier, yeah u can reuse your old stuff (axles,etc...), you'll have to wire up the VTEC oil, VTEC oil ground, and VTEC switch, make sure u get the ecu (I think u can use a V-AFC instead). Since the CX tranny has longer gears, it'd be better for turbo. If u wanna go all-motor use a EX/Si. If uR broke, use what u got, lol.
Re: sohc swap ??? (marked001)
look at the pass. side harness, if you have a orange/white & orange/blue, the vtec wires are there, orange/white go to the seliond orange/blue go to the switch, then ground the switch call it a day, you got vtec baby
rdaggett
03-08-2005 09:09 AM
