How to build a poor mans type r
Old Jun 14, 2007 | 10:23 PM
sontdawg's Avatar
Default How to build a poor mans type r
Need a basic lay out on how to get the right setup on the "poor mans type r" i have the head and block and i am ready to start putting together
what do i need ecu wise and what gaskets will i run and other little things that need to be done any post will be a help im not clueless just trying to get it done right
Old Jun 14, 2007 | 10:35 PM
crxnj's Avatar
Default Re: How to build a poor mans type r (sontdawg)
b18c gsr block
b16a head
type-r pistons
type-r cams
type-r intake manifold
For ecu ,you'll need something custom since i doubt you'll convert to obd2 and run the original type-r ecu..You have to decide if you want to stat obd0 or go obd1,,but either way you'll end up with a chipped ecu..
Old Jun 14, 2007 | 11:18 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
throw in an LS crank too
Old Jun 15, 2007 | 12:14 AM
mr.speaker's Avatar
Default Re: (jdm_dc_fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_dc_fan &raquo;</TD></TR><TR><TD CLASS="quote">throw in an LS crank too </TD></TR></TABLE>
Why would he want to do that? then he would need ls rods as well,,which is a major degrade for the whole purpose of this motor,which is to rev high.......
Old Jun 15, 2007 | 01:09 AM
jdm_dc_fan's Avatar
was thinking he was using aftermarket rods. too much time in the FI forum.
Old Jun 15, 2007 | 05:40 PM
sontdawg's Avatar
why would i have to purchase
cams
pistons
and intake manny
why wouldnt my b16 intake manny and cams work in there?
just asking
Old Jun 15, 2007 | 06:04 PM
STREETWERKZ's Avatar
Default Re: (sontdawg)
they would work.
but then it wouldnt really be a poor mans <FONT COLOR="red">R</FONT>, now would it?
it would be a poor mans, GSR.
Old Jun 15, 2007 | 06:08 PM
sontdawg's Avatar
lol got it i got b18c5 pistons and rods ordered i will do the cam and intake work later not enough doe right now but thanks guys for the help
Old Jun 15, 2007 | 06:09 PM
cool, good luck.
used cams go for about $300. so it probably wont be that hard to get some.
Old Jun 15, 2007 | 06:11 PM
sontdawg's Avatar
lol got it i order pistons and rods for a b18c5 but i will to cam and intake work later
about the chipped ecu i am 0bd1 right now what should i do about that or would that work on there with the head and block
Old Jun 15, 2007 | 07:41 PM
mr.speaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sontdawg &raquo;</TD></TR><TR><TD CLASS="quote">lol got it i order pistons and rods for a b18c5 but i will to cam and intake work later
about the chipped ecu i am 0bd1 right now what should i do about that or would that work on there with the head and block</TD></TR></TABLE>
you dont need rods..just the pistons
since you're obd1 already that's a good start..I'm assuming you have the p30 ecu since you have a b16a? If so, you can use that on the new motor,it will run it fine but eventually you'll want to get it chipped with a tune thats better for that motor.Since there's no obd1 type-r fuel and timing map available,you'll have to get a custom tune thats worked .Ive seen most use gsr maps as their start then work from there..
Old Nov 9, 2008 | 04:16 PM
Dc2Fiend's Avatar
Default Re: How to build a poor mans type r (mr.speaker)
VTLX 03R
Jan 8, 2014 01:13 PM
FST96Integra
Jan 12, 2005 09:45 PM
SkyLinER
May 12, 2004 09:34 AM
DoctorGSR
Aug 17, 2003 09:35 PM
