check engine light
Old Jun 14, 2007 | 07:23 PM
racerxfactor's Avatar
Default check engine light
i have a 89 civic with a b16a swap. my check engine light just started going on today and it goes on and off. bright one minute then dim then next. i was in rush hour traffic, i don't know if that helps but does anyone know what it could mean?
thanks
Old Jun 14, 2007 | 07:27 PM
.Grimace's Avatar
footwork mastery
Default Re: check engine light (racerxfactor)
check what code it is. that would help us a lot.
Old Jun 14, 2007 | 07:30 PM
DenzComp's Avatar
Count the flashes coming from the ECU and let us know.
Old Jun 14, 2007 | 07:40 PM
Default Re: check engine light (Gremice)
how?
Default Re: (DenzComp)
and how? the light stays on awhile then goes off for awhile then again.... is that what you mean?
Old Jun 14, 2007 | 07:41 PM
DenzComp's Avatar
Pull back the carpeting on the passenger side...underneath the dash. You'll see a little window. Turn the key on one click, then look in that little window. There is a light in there that flashes.
Old Jun 14, 2007 | 07:54 PM
.Grimace's Avatar
footwork mastery
a long flash = 10. a short flash = 1.
Old Jun 14, 2007 | 08:39 PM
Default Re: (Gremice)
i guess if you were talking about the flash on the dashboard then it's a 10
Old Jun 14, 2007 | 08:41 PM
cr-x-91's Avatar
on ur ecu under the passenger crapet.
Old Jun 14, 2007 | 08:42 PM
DenzComp's Avatar
I'm telling you man....pull the carpet back and look. It has nothing to do with the check engine light right now...the ECU is the "computer". It will normally tell you what is wrong with your car. Pull the carpet back and find the window and do what I said before.
Old Jun 14, 2007 | 08:44 PM
cr-x-91's Avatar
and if its 10, than its i.a.t=intake air temp sensor.
Old Jun 14, 2007 | 08:51 PM
i didn't see any light coming from underneath the dash when i pulled the carpet out
Old Jun 14, 2007 | 08:57 PM
cr-x-91's Avatar
do you know what ur ecu looks like? its boxy and gold. its has a triangled window so u can c the l.e.d light flashing codes....kinda like mors code. a long flash =10 than every quick flash =1...than u add them up and u will get the code,than we can help you budd...good luck,its okay if u dont know alot about cars. were here to help one another.
Old Jun 15, 2007 | 06:38 AM
Default Re: (cr-x-91)
i remember the actual ecu as a box with chips in it that connects underneath the dash. don't remember a window...
Old Jun 15, 2007 | 06:59 AM
90crxdriver's Avatar
ECU
89civichb
May 10, 2007 06:42 PM
91civicmaine
Mar 16, 2006 09:37 AM
Project_EK
Aug 13, 2005 04:08 PM
Wayne64SS
Jun 26, 2003 10:01 PM
ex_crxer
Apr 6, 2002 07:54 AM
