cooling fan won't turn on
I have an 89 Si. My cooling fan doesn't turn on at all. The temp switch (attached to the engine block) works fine, the temp guage is accurate, I checked the fuse under the dash, tested the relay for continuity (it made a clicking noise when the C and D terminals were connected via speaker wire to the battery), and I connected the fan directly to the battery to make sure the fan motor wasn't bad.
Why else would the cooling fan not turn on when the temp guage is already 3/4 the way to 'H'? Is this something I could do myself while following the shop manual?
Thanks!
Thanks!
i would get a mechanical water temp gauge and see if your getting the same results as the stock gauge. opperating temp should be around 180-200 depending on your thermostat. did you check all the grounds? clean off the bolts and sand down the paint that it grounds to. hopefully that will work
great info ^
On the back of the block, the coolant temp switch works by allowing continuity between the terminals A and B, once it has reached a high enough temp (about 190 F).
There are 2 wires going to the coolant temp switch:
Black = Ground (verify a good ground)
Yellow/green = 12 Volts+ (when key is in ignition)
When the switch reaches temp, it allows the Yellow/green wire to contact ground.
You can simulate the switch being activated, by directly grounding out the Yellow/green wire (with the key in the ignition). If you ground out the yellow/green wire and the fan comes on, then it is probably a bad coolant temp switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wm07 »</TD></TR><TR><TD CLASS="quote">It's the relay...</TD></TR></TABLE>
Thats what I was going to say as well. They can be intermittent
Eglifestyle
10
Mar 23, 2008 12:08 PM
vti444
Aug 22, 2007 08:51 AM
