Speedo not working...in need of help
Old Jun 13, 2007 | 06:00 PM
chinkcity07's Avatar
Default Speedo not working...in need of help
my speedometer is not working. it flickers up to 60 or 40 every once in awhile. every other guage works. i had changed the VSS( Vehicle Speed Sensor) and both o2 sensors and neither had fixed the problem. please, any help would be greatly appreciated, thanks
Old Jun 14, 2007 | 07:21 AM
dbiker207's Avatar
Default Re: Speedo not working...in need of help (*****city07)
what car is this? what year? is there any check engine lights? does vtec engage?
Old Jun 14, 2007 | 11:32 AM
95strfytr's Avatar
i'm assuming that it is odb2 (both o2 sensors). Is the VSS plug loose? My civic was having issues like that and i found out that after I changed my VSS, the plug connecting to it had rattled loose because somehow the clip on it broke. I changed the clip and haven't had any problems since. Have you pulled out the gauge cluster in the dash recently? If so, a plug issue could have occurred there, too.
Old Jun 14, 2007 | 01:15 PM
ndogg's Avatar
i had a similar problem, the pins in the plug were rusted out causing intermittent connection.
092eg6
10
Oct 29, 2010 08:49 AM
firo
Jul 26, 2007 04:52 PM
ek4h
Apr 15, 2007 07:49 PM
delviacv2
Nov 16, 2004 12:49 AM
gaydm.accord
Dec 18, 2003 10:33 AM
