99' si A/c Compressor problems.
Old Jun 13, 2007 | 02:35 PM
Shaun_'s Avatar
Default 99' si A/c Compressor problems.
I just reinstalled the A/C belt after 4 months of it being off the car and now the a/c sucks ***. It worked great before. I also added some r134a to the system, when i did that it appeared that the compressor clutch would kick on then after a second or two it would kick off. Anyu ideas?
Old Jun 13, 2007 | 03:25 PM
Shaun_'s Avatar
bump
Old Jun 13, 2007 | 03:34 PM
em18u's Avatar
Default Re: (Shaun_)
yea its probaly cutting on and off becuase it dosent have the right amount of refrigerent. get it vaccum tested and charged by a good quality machine!!!
Old Jun 13, 2007 | 04:44 PM
robfrmny21's Avatar
if you over charged the system that is just as bad as uner charged.. i think you added to much..
take it to a shop and have it sucked all out pull a vacumm and put back in the right about of freon
Old Jun 13, 2007 | 05:23 PM
Shaun_'s Avatar
I work a second job at a jiffy lube and we have a machine there that you hook a line up the the High Pressure side and the low pressure side and it does a complete flush. I will have to try it out.
Old Jun 20, 2007 | 12:26 PM
Shaun_'s Avatar
bump
Sinner
Aug 9, 2022 06:27 PM
EF7
Sep 26, 2012 08:12 PM
Deviant117
Jun 28, 2012 11:52 AM
greg51
18
Jun 8, 2011 01:02 PM
dmoore2920
Jan 4, 2010 02:04 PM
