99' si A/c Compressor problems.
I just reinstalled the A/C belt after 4 months of it being off the car and now the a/c sucks ***. It worked great before. I also added some r134a to the system, when i did that it appeared that the compressor clutch would kick on then after a second or two it would kick off. Anyu ideas?
Re: (Shaun_)
yea its probaly cutting on and off becuase it dosent have the right amount of refrigerent. get it vaccum tested and charged by a good quality machine!!!
if you over charged the system that is just as bad as uner charged.. i think you added to much..
take it to a shop and have it sucked all out pull a vacumm and put back in the right about of freon
I work a second job at a jiffy lube and we have a machine there that you hook a line up the the High Pressure side and the low pressure side and it does a complete flush. I will have to try it out.
Deviant117
06-28-2012 11:52 AM
greg51
18
06-08-2011 01:02 PM
