How can make my bumber lights stay on??
Old Jun 13, 2007 | 10:51 AM
USDMED7's Avatar
Default Would this work whit my lights????
I seen people driving ef whit the usdm bumber but there lights for the turning signal stay on like some kind of fog light.I want to try it but i dont know if by me connecting the the corner lights whit the lights at the bottom would it work?? plzzz gimmi some advice
Modified by USDMED7 at 12:02 PM 6/13/2007
Modified by USDMED7 at 12:04 PM 6/13/2007
Old Jun 13, 2007 | 11:24 AM
sirhavok's Avatar
you need to get a double light connector. i forgot the correct name for it is. basically you go to the junk yard. and get the house for you back parking lights,
and replace your turn signals with those.
its pretty easy.
srry i dont know the correct terms.
Old Jun 13, 2007 | 01:57 PM
Jonny Rocket's Avatar
Default Re: Would this work whit my lights???? (USDMED7)
I wanted to do that too. I didnt think anyone has done it. Let me know how it went. please
Old Jun 13, 2007 | 02:06 PM
89efDUSTY's Avatar
Default Re: Would this work whit my lights???? (Jonny Rocket)
Just hook up the postive to a 12V either constant or switch activated...if you want them on with you lights just use your power from your headlights spliced with a wire to your turn signals, then just ground to the chassis. Or use your existing harness and just fabricate it using that.
Boosted_CRX_507's Avatar
do the wires from the tailight harness match up to the corners?
Old Jun 13, 2007 | 05:18 PM
Crx Jimmy's Avatar
Default Re: Would this work whit my lights???? (Boosted_CRX_507)
you dont need tail light socket or a 2 filament bulb, you can achieve this with a relay so the light remains on fully bright when the lights are on, then the blinker trips the relay so it flashes.
Old Jun 13, 2007 | 05:47 PM
janz3n's Avatar
Default Re: Would this work whit my lights???? (Crx Jimmy)
holy crap theres actually a write up for this.. try searching for it.
Old Jun 13, 2007 | 07:12 PM
USDMED7's Avatar
ok im doing tomorrow i hope is that easy..because i would like to make so i could turn off the head lights and just have the corner and both turning signals on(off cours whitout the blinking)if u have any other suggestions let me know.I would check before i start.Thank u
Old Jun 13, 2007 | 10:02 PM
lol
so
what kinda relay?
rdemel
Honda Civic (2001 - 2005)
May 15, 2017 05:26 AM
beginmyhonda
Aug 4, 2011 08:01 AM
h22egAZ
Nov 19, 2006 11:02 AM
yellowjdmcrx
23
Jul 30, 2006 10:20 AM
sleepyEK
27
Mar 20, 2005 07:43 PM
