Fuel injector clips won't fit!!! help!!!
Old Jun 12, 2007 | 08:12 PM
Addicted 2 Adrenaline's Avatar
Default Fuel injector clips won't fit!!! help!!!
I'm using my my stock harness from my 97 civic ek and i'm swapin' a 94 GSR motor...everythin' is converted to OBD2 but the fuel injector clips won't fit on there....is there a way that I can make it fit? give me some suggestion....Splice it or whatever you guys can think of to make it fit...thanks
Old Jun 12, 2007 | 08:56 PM
GsrTurboCRX88's Avatar
Default Re: Fuel injector clips won't fit!!! help!!! (Addicted 2 Adrenaline)
keep trying, they are all the same. maybe yours are bent
Old Jun 13, 2007 | 12:46 AM
Default Re: Fuel injector clips won't fit!!! help!!! (GsrTurboCRX88)
yeah, I tried but it won't go in....but when i tried it on my stock D series injector it went in no problem.
Old Jun 13, 2007 | 04:34 AM
evilsolb16's Avatar
why dont you use you stock injectors, are the gsr injectors obd2 if its a 94 then they are not. just use you sohc injectors
Old Jun 13, 2007 | 04:36 AM
g23_ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrTurboCRX88 &raquo;</TD></TR><TR><TD CLASS="quote">keep trying, they are all the same. maybe yours are bent</TD></TR></TABLE>
not true.. make sure you are using the right injectors.. if you want to utilize your harness and not have to rewire, find the right injectors.. if you dont mind, i would just find the right clips and solder them in.. clips from junk yard is cheaper then buying injectors..
Old Jun 13, 2007 | 05:17 AM
Default Re: Fuel injector clips won't fit!!! help!!! (evilsolb16)
I tried usin' the SOHC injectors but they seem kind of short...the fuel rail is baraley on top if the injectors.
Old Jun 13, 2007 | 09:12 PM
Default Re: Fuel injector clips won't fit!!! help!!! (g23_ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g23_ej1 &raquo;</TD></TR><TR><TD CLASS="quote">
not true.. make sure you are using the right injectors.. if you want to utilize your harness and not have to rewire, find the right injectors.. if you dont mind, i would just find the right clips and solder them in.. clips from junk yard is cheaper then buying injectors.. </TD></TR></TABLE>
My bad, i thought he was talking about the metal wire clip, not the harness connector
Old Jun 13, 2007 | 09:16 PM
Civette's Avatar
as long as the motor isnt turbo'ed the sohc injector will work fine......but change the pigtails and injectors as soon as you can.....done it many many times
Old Jun 13, 2007 | 09:21 PM
Syndacate's Avatar
Default Re: Fuel injector clips won't fit!!! help!!! (Civette)
No they aren't, OBD-I injectors are diff from OBD-II injectors as far as I know.
You need OBD-I injectors. Stock 240's off a Z6 will work fine for a stock GSR.
Old Jun 14, 2007 | 03:54 AM
Default Re: Fuel injector clips won't fit!!! help!!! (Syndacate)
nvm...I used my SOHC injectors and it fits...thanks to all...
Old Jun 14, 2007 | 09:16 AM
b20beast978's Avatar
sohc injectors should get the job done!
they are interchangable, b and d series are all 240cc
blkb18
May 18, 2008 05:42 PM
Archidictus
Jul 23, 2007 12:13 PM
Hawks-At-Angels-12
Jul 7, 2006 02:07 PM
BOOSTED_JDM_DB8
May 15, 2006 07:07 PM
SlowB16si
Mar 13, 2006 11:46 AM
