RC440 Injectors in Canada
Old Jul 5, 2006 | 09:42 PM
Hawks-At-Angels-12's Avatar
Default RC440 Injectors in Canada
Someone please help. Iv been scammed out by Klubhead1/eg6turb0 etc... he sent me injectors that don't even fit my car.
Would anyone know of a place in Canada that I could get a set of RC440 injectors ... I need them sent overnight ASAP.
Someone please help
Old Jul 5, 2006 | 10:19 PM
pgmatt's Avatar
Default Re: RC440 Injectors in Canada (Hawks-At-Angels-12)
What did he send you and why dont they fit your car?
Old Jul 6, 2006 | 06:49 AM
MeekalLS's Avatar
Default Re: RC440 Injectors in Canada (pgmatt)
https://honda-tech.com/zeropost...80593
Those
Old Jul 6, 2006 | 07:00 AM
Jon at Titan's Avatar
Did you get the Injector Clips that come with the RC, Also what year is your Car ? if its OBd2 you will Obd1 Clips and wire them into your Injector Harness to fit the RC's.
Hope that Helps. now if its the Injectors that dont fit into the manifold then that is a different problem.
Old Jul 6, 2006 | 08:33 AM
Default Re: (jnasty1845)
They don't fit in to the manifold either.
Old Jul 6, 2006 | 10:29 AM
dpetro1's Avatar
Default Re: (Hawks-At-Angels-12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawks-At-Angels-12 &raquo;</TD></TR><TR><TD CLASS="quote">They don't fit in to the manifold either. </TD></TR></TABLE>
rc injectors dont push into the injectors seals, they sit on top and create a seal that way. also they should plug right in on your obd1 harness. i run rc550's but i believe the pn is sl9-550.
give RC a call and see if that is the right part# for your application. they can also email you installation instructions.
Old Jul 7, 2006 | 02:07 PM
roadrunner's Avatar
I just replaced the injector seals for my RC 440s on my 97 GSR -- I was told by RC that I could use either 92 Prelude Si lower injector seals or 92 Integra LS lower injector seals. I bought the 92 Integra LS lower seals and like dpetro1 states, they sit on top of the seals and the fuel rail pushes them down.
BOOSTED_JDM_DB8
May 15, 2006 07:07 PM
b17integra
Jun 19, 2005 05:40 PM
jdmcx
Jul 12, 2003 04:51 AM
move_right
Dec 22, 2002 07:45 AM
