96 civic sedan with windows that dont roll down
do you have a window lock button on the door that might be pushed on by accident? not even trying to be a smart *** either...happened to me and it was the last place i looked cause i really didnt expect it
so both passenger windows dont work? or just one of them?
check the plastic plugs going into the doors(bringing the wires is) if those are plugged in then you need to just find out where the power stops, test it after the regulators and before and as far back to the fuse box as need be and youll find your problem
found the problem, on the out side of the door there are wires the plug in to the door harness there was 4 wires that broke off, that would not allow my windows and door looks to work. keep that in mind when that ever happens to you!
Sandrunner16
Feb 26, 2017 07:58 PM
