Do you need a compressor to install shocks?
Old Jun 4, 2002 | 09:16 PM
dvp95's Avatar
Default Do you need a compressor to install shocks?
Hey I have a 96 accord with neuspeed sport springs. Im going to get either tokicos or kybs, but do I need to compress the springs to get it back in? Or is it ok because they are already shorter than stock?
Old Jun 4, 2002 | 09:18 PM
4doorH22's Avatar
Default Re: Do you need a compressor to install shocks? (dvp95)
You should be okay.
Old Jun 4, 2002 | 09:22 PM
Nick H's Avatar
New User
Default Re: Do you need a compressor to install shocks? (4doorH22)
Old Jun 4, 2002 | 09:25 PM
4doorH22's Avatar
Default Re: Do you need a compressor to install shocks? (nickh2k1)
My H&R Sports didn't require a compressor
Old Jun 4, 2002 | 09:44 PM
Nick H's Avatar
New User
did you just place the spring on the shock and lower the car back onto it?
Old Jun 4, 2002 | 09:45 PM
Accord94DX's Avatar
hmm....perhaps you will need one for the fronts. Have a tubby friend hold down the springs while you tighten the nut, or borrow a compressor.
Old Jun 4, 2002 | 10:58 PM
Brandon's Avatar
Life is Suffering
Default Re: Do you need a compressor to install shocks? (Accord94DX)
Brian, the cubby friend would have a tough time with the 2000lbs of force needed to compress the springs, but yes, you will need a spring compressor. They, like many other automotive specialty tools, can be rented. At a price. Best bet is to take it to a shop, but DIY is just as good most of the time as long as all of the bolts have the correct amount of tourque.
Old Jun 4, 2002 | 11:10 PM
Accord94DX's Avatar
Default Re: Do you need a compressor to install shocks? (vtec2k2)
By cubby i assume you mean my previous mention of tubby. Well, here is the breakdown, if you have a chubby *** friend whose mass is greater than the spring rate, physics says the fatass will be the victor assuming he can direct enough tubby onto the spring hat.
Old Jun 5, 2002 | 01:32 AM
CD8's Avatar
CD8
neuspeed sports are NOT 2000lb springs. you do not need 2000lbs of force to comprese them. that is just ridiculous.
you should use a compressor... but you dont need one.
Old Jun 5, 2002 | 01:44 AM
Brandon's Avatar
Life is Suffering
Default Re: Do you need a compressor to install shocks? (exaccord)
They are more than 400lb/in springs and will need about 3 in of compression, which would be 1200lbs, sorry, I was wrong. BTW, you will need a spring compressor badly if you are not using shortened shocks or coilovers.
Old Jun 5, 2002 | 01:48 AM
CD8's Avatar
CD8
neuspeed sports are NOT 400lb springs either. they are around 185/245 r/f.
thats what the neuspeed man told me when i emailed em... neuspeed race's on the other hand are 400lb springs.
[Modified by exaccord, 2:49 AM 6/5/2002]
Old Jun 5, 2002 | 01:52 AM
Brandon's Avatar
Life is Suffering
Oh well. To many brands to keep up with. Still needs a compressor though.
Old Jun 5, 2002 | 01:56 AM
CD8's Avatar
CD8
lol... yes you are right about that... i needed a compressor for the front ones, not for the rear. i was installing them with koni's too. what a waste though... i got rid of them less than a month later after one autoX event.
Old Jun 5, 2002 | 04:24 AM
TypeSH's Avatar
Hello,
The SofSport and Sport springs have the same working spring rate which is 260 lb/in up front while the rear is 165 lb/in. The Race is more aggressive at 485 lb/in up front while the rear is 300 lb/in. For further product information, ordering procedures, or a dealer near you, please feel free to give our sales staff a call at (800)423-3623 or (805)388-7171 or you may fax them at (805)388-0030. Thank you for your inquiry!
Best regards,
Danny
I'm not sure if you need a compressor for neuspeed sports, but for eibach prokits (~1-1.5" drop), I had to use a compressor for the fronts. The rear was easy to do.
Old Jun 5, 2002 | 04:38 AM
John's Avatar
New User
I used to have Neuspeed sports, and when I installed them with my Konis, I did have to put a little weight down to compress the spring. I had no problem doing this, and I'm only 145lb.
j00 can do it!
Old Jun 5, 2002 | 07:02 AM
bmm89's Avatar
no, i installed the sports w/o compressor for the sprot springs up i highly suggest getting one to brace the oem,they pop out quite a bit in the rear
also just in case, they are free to rent with deposit at any major auto store(autozone, pepboys, etc..)
EFinawesomeman
22
Aug 7, 2007 08:03 PM
budget
Jun 30, 2006 10:45 AM
winnerpl
Suspension & Brakes
May 18, 2006 09:43 PM
Blazin Civic
Suspension & Brakes
15
Jun 20, 2005 05:53 AM
CRX-RX
Jan 23, 2002 10:49 AM
