what kind of gasket are all y'all using for your manifold to turbo and turbo to dp?
Old Jun 4, 2002 | 07:29 PM
bruthaboost's Avatar
Default what kind of gasket are all y'all using for your manifold to turbo and turbo to dp?
I remember some posts where people were mentioning running without them. As I was about to turn the ignition key finally, I give Type C a call and he warned me of the perils of running without gaskets. Now I'm wondering, what type are all y'all using.
BTW I have the max rev mani, turbo (4 bolt flange), dp. Later this week I'll have pics of the whole setup and man has it been a pita. I've done a few extra mods which made the install a little longer.
Old Jun 4, 2002 | 07:31 PM
kidkutz's Avatar
Default Re: what kind of gasket are all y'all using for your manifold to turbo and turbo to dp? (bruthaboost
i had my friend make me a copper T3 gasket...it sealed great!
Old Jun 4, 2002 | 07:37 PM
Yeah, copper is nice and soft (flowing). How thick was it?
Old Jun 4, 2002 | 07:48 PM
Jared's Avatar
I'm using GM high temp silicone. Works great and doesn't leak at all.
Old Jun 4, 2002 | 07:55 PM
Ri5e's Avatar
I dont use any gaskets.
Old Jun 4, 2002 | 10:00 PM
inspyral's Avatar
Mine worked great for a couple days, then it blew out
Old Jun 4, 2002 | 10:15 PM
NeXtLeVeL_TyPe_R's Avatar
not running any gaskets
Old Jun 5, 2002 | 12:03 AM
quickspoolin's Avatar
I'd rather use no gasket than the silicone stuff. Silicone under pressure doesn't hold to well.
silicone gaskets for force induction=
Old Jun 5, 2002 | 01:16 AM
dbman96's Avatar
New User
Wouldn't worry so much about the pressure as the 1600 degree F exhaust temps...
There is a standard gasket for T3 turbo manifold flanges - Turbonetics sells them at http://www.turbocharged.com and your local ford dealer can get them if you look for the gasket from a thunderbird turbo coupe (1987ish?) or Merkur XR4Ti, among others.
Old Jun 5, 2002 | 01:26 AM
Flamenco-T's Avatar
yep, just go to ford dealer and get an 86 T-bird gasket. U se a metal one, or don;t use one at all....as long as both surfaces are clean and flat,, the carbon will seal it up..
Old Jun 5, 2002 | 01:28 AM
Flamenco-T's Avatar
nice name Jeff..
Old Jun 5, 2002 | 01:42 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
STock. or at least, that's what I'm going to use when I install it.
Old Jun 5, 2002 | 06:31 AM
X2BOARD's Avatar
Umm... it's steel isn't it ? Just the standard T3 gasket for the turbo to the manifold and no gasket to the DP.
Old Jun 5, 2002 | 10:03 AM
Why thank you Stan. That's right nice of ya. Also FYI for everyone: According to my local Ford dealerships the T3 turbo manifold gasket has been discontinued. Guess I'll be running gasketless.
Old Jun 5, 2002 | 10:17 AM
SIK IN DA HED's Avatar
New User
you guys dont run gaskets to your downpipe and to the turbo? hmmmm dont u get leaks?
93grayeg
Sep 11, 2024 07:33 PM
pcguy760
Aug 29, 2008 07:03 PM
jb0705
May 16, 2006 11:23 AM
wacktical
Jun 15, 2005 01:23 PM
pg_thao
May 23, 2003 05:10 PM
