Weird problem
Ok when the car is cold, and i drive it normal, i hit the gas and it goes for a min then louses power, bu dose not die and drops back, and gains power again, and then drops back again, until it gets warm or i punch the gas, any help?
did you mess with the idle screw, if so put it back the way it was. maybe be something with vacume also. friend had this problem and i fix the screw and drives normal. i think the ecu has something to do with recognizing it.
prendi
20
Apr 14, 2003 01:51 PM
