how do you get a tps sensor out
take off TB and with a dremel or small file, file a slot for a screwdriver. Replace bolts with much easier to use ones.
Option 2.....dremel off head of bolt completely (dont *** up tps sensor) and pull off tps, then remove old bolts and replace with new bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">take off TB and with a dremel or small file, file a slot for a screwdriver. Replace bolts with much easier to use ones.
Option 2.....dremel off head of bolt completely (dont *** up tps sensor) and pull off tps, then remove old bolts and replace with new bolts.</TD></TR></TABLE>
or get vice grips and a torx bit....
91integraLSVTEC
Nov 11, 2005 10:38 PM
