Timing for ls/vtec help
Old Jun 11, 2007 | 01:49 PM
ganjasnack's Avatar
Default Timing for ls/vtec help
i just got my motor back from the machine shop i have a b18a block with a gsr head. i have a greddy gsr timing belt, gsr water pump and type r oil pump. i set the notch on the oil pump gear to the arrow on the pump. i have skunk2 pro series cam gears and i set the notches on that to the ones on the back of the cam cover. now when i put my timing belt on i go by the book and after i tension the belt and turn it over a few rotations the white mark on the crank pulley is off what seems like a tooth (white mark is just past the pointer on timing cover going counter clockwise) but nothing moved the cams or the crank when i put the belt on. it does seem like there is a little slack in the belt between the cam gears but they are lined up exactly to the marks. and then i go to start it and it runs like its off time. what could be doing this? please help!
Old Jun 12, 2007 | 09:15 AM
ganjasnack's Avatar
Default Re: Timing for ls/vtec help (ganjasnack)
anyone?
revhardEK
Apr 5, 2012 09:03 AM
ganjasnack
Jun 12, 2007 01:22 PM
Renegade
Feb 13, 2007 08:01 AM
only4cylinders
Apr 8, 2005 12:18 PM
PM-Performance
Jun 3, 2004 04:51 PM
