ecu guru's help
Old Jun 11, 2007 | 01:40 PM
v.i.gsr's Avatar
Default ecu guru's help
I need to know the number of this transistor off of a p30 ecu. It is located in the q31 position on the ecu board. Its the one thats burned in the pic. (sorry for the crappy pic)
Modified by v.i.gsr at 1:47 AM 6/13/2007
Old Jun 11, 2007 | 07:17 PM
v.i.gsr's Avatar
Default Re: ecu guru's help (v.i.gsr)
bump
Old Jun 11, 2007 | 08:30 PM
Jim Truett's Avatar
2SD1779 or 2SD1780. Long discontinued. It is the driver for the purge solenoid and not really necessary for operation.
Old Jun 12, 2007 | 09:49 PM
v.i.gsr's Avatar
Default Re: ecu guru's help (Jim Truett)
[QUOTE=Jim Truett]2SD1779 or 2SD1780. Long discontinued. It is the driver for the purge solenoid and not really necessary for operation.
Why am i getting a code for the o2 sensor, if its for the purge solenoid.
Old Jun 13, 2007 | 04:58 AM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v.i.gsr &raquo;</TD></TR><TR><TD CLASS="quote">
Why am i getting a code for the o2 sensor, if its for the purge solenoid.</TD></TR></TABLE>
Only you can figure that one out.
What code is stored in the ECU?
Old Jun 13, 2007 | 11:11 PM
v.i.gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">
What code is stored in the ECU?</TD></TR></TABLE>
I reset the ecu, and started the car back up and its throws a code for the o2 sensor. (code 41)
Old Jun 14, 2007 | 05:01 AM
Jim Truett's Avatar
41 is the o2 heater or it's circuitry. Either the sensor itself is bad, the wires going to it are defective, or the driver circuitry in the ECU has failed.
Old Jun 14, 2007 | 12:00 PM
v.i.gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">41 is the o2 heater or it's circuitry. Either the sensor itself is bad, the wires going to it are defective, or the driver circuitry in the ECU has failed.</TD></TR></TABLE>
Its a brand new bosch o2 sensor, and i checked all the wiring in the harness and their good.
nolicense526
Jun 27, 2007 07:02 PM
95CivicGSR707
Apr 15, 2007 09:39 PM
jdrannow
Oct 3, 2005 01:35 PM
initialR
Jan 10, 2005 10:06 AM
gary201147
Mar 7, 2004 01:21 PM
