Turbo Timer help!
I had installed a greddy full auto timer and it worked perfect. I have my turbo timer in the EG audio console, i had to take the audio console out becuase i needed to switch out my shift which consisted of unplugging the TT, when i put everything back together the turbo timer now doesnt work. it would click on then just turn back off..
Now today i cheked all the wire with a voltmeter and on 92-95 civics they have 2 ignition wires one has constant 12v and one drops 12v when you activates the starter.. i checked it and they both drop voltage??? and when i turn the key right before it activates the starter the turbo timer comes on and stays on???
PLEASE ALL THE HELP IS GREATLY APPRECIATED
ok on the back of the ignition cylinder there is a small yellow wire and a black with yellow stripe those should be the wires on the back that you would use for the turbo timer to work properly.. double check to make sure i just did mine this weekend
J.nguyen
Sep 30, 2006 04:27 PM
