Turbo Timer help!
Old Jun 11, 2007 | 01:02 PM
CHINKA's Avatar
Default Turbo Timer help!
I had installed a greddy full auto timer and it worked perfect. I have my turbo timer in the EG audio console, i had to take the audio console out becuase i needed to switch out my shift which consisted of unplugging the TT, when i put everything back together the turbo timer now doesnt work. it would click on then just turn back off..
Now today i cheked all the wire with a voltmeter and on 92-95 civics they have 2 ignition wires one has constant 12v and one drops 12v when you activates the starter.. i checked it and they both drop voltage??? and when i turn the key right before it activates the starter the turbo timer comes on and stays on???
PLEASE ALL THE HELP IS GREATLY APPRECIATED
Old Jun 12, 2007 | 10:07 PM
insaneconceptz's Avatar
Default Re: Turbo Timer help! (*****A)
ok on the back of the ignition cylinder there is a small yellow wire and a black with yellow stripe those should be the wires on the back that you would use for the turbo timer to work properly.. double check to make sure i just did mine this weekend
NightStalker
Sep 3, 2007 01:10 PM
sinfulDB1
Oct 30, 2003 10:53 PM
rbf351
Audio / Security / Video
Nov 23, 2002 06:06 PM
