open 96 civic door
hi all,
I'm trying to open my 96 civic inside door coer, but there feels like a screw at the handle ( in the center).
I got all the edges' screw out, but still cannot prop the inside cover off. i really want to fix my window. seems like there is a slip in the piece that pushes the window up.
Please help.
If this doesn't make sense, please tell me. Or if you could make things a lot easier, please tell me where are all the screw is?
Please help.
There's a screw on the panel where the door meets the dash, one in the cup-like handle on the door, and one inside the door latch.
Just 3, and you'll need to unplug your speaker.
There's a screw right where you grab in the handle, yes. Also, keep in mind that you have to remove your speaker, tweeter and the clips that hold the door panel unto your door. Get a flat, skinny screw driver to pry them loose. Pop off the speaker cover, and remove the speaker screws holding it in. Unplug the wire plugin to the speaker; and then unscrew the three screws that are in a triangle like pattern around the speaker area. I know I'm forgetting a few things
i can't open the door handle. i tried pushing in those plastic slots that holds it together, but i just can't seem to detech it. I see three of them.
will anyone be wiling to give me a photo of how to open it? or how it should look like after the handle is open? I'm just a visual learner.Please help
1997exciv12w3
Sep 3, 2002 05:12 PM
