how to remove civic door panel????
my drivers side pwerwindow came off track i think. How would i remove the door panel and would i jus put it bakon track once i take t of???
Re: how to remove civic door panel???? (1997exciv12w3)
This is for a non power anythign door, but here ya go. There is one screw in the door handle surround (dont know what it's called), one screw in the little cup about halfway down the door panel and there are 3 screws around the outside of the speaker. You'll also have to take out your speaker. Next you can either use a tool to pop out the little clips that hold on the door panel itslef of you can just pull...they're kind of stubborn, but they'll come off. I think you can just put the window back on the track once you get the door panel off, but you are going to have to remove the plastic sheet behind the door panel to get to it. Good luck!
