Timing Adjustment Help.....
Old Jun 10, 2007 | 08:20 PM
SilverGT's Avatar
Default Timing Adjustment Help.....d16y7 motor
I had my timing light on the car today.....and i dont know what the expletive im doing lol....i thought i could learn it by myself but im confused on the marking of the crank pully
I can see its like this
where should my arrow be? the arrow or V should be?
As of righthow it looks like this
.......V
If you konw where its supoosed to be at let mek now i have searched didn find anything,
I have a 1997 Honda Civic Sedan 4 door
stock motor....
Old Jun 11, 2007 | 06:08 PM
sexyrex's Avatar
Default Re: Timing Adjustment Help.....d16y7 motor (SilverGT)
why do you need to check timing anyway? you off a tooth or something?
but anyway jump your timing connector, i believe for your car its below the passenger dash near the ecu. should be coming off a wire harness.
use a paper clip, cotter pin or w/e....
start your car and warm it up. get your timing light out set your timing light at 16 degrees. the pointer on the timing cover should line up with the red mark. if its a bit off, move your dizzy. thats it...
Old Jun 11, 2007 | 06:28 PM
doood's Avatar
been there done that
that "V" should line up with the middle mark which is 16*btdc
Old Jun 11, 2007 | 06:50 PM
sexyrex's Avatar
Default Re: Timing Adjustment Help.....d16y7 motor (doood)
will there is the sight and than theres a pointer...you need to look through both to line up correctly
pimpwagon
Dec 7, 2010 05:55 PM
NSfit
10
Nov 14, 2006 11:17 AM
nick32
Dec 28, 2005 01:48 PM
importlegions
11
Apr 14, 2005 06:13 PM
racingant
Jul 17, 2004 10:06 AM
