Installing exhaust system
Old Jun 10, 2007 | 02:04 PM
EJ8 Kenobi's Avatar
Default Installing exhaust system
I'm installing a new (used) dc sport header and I bought a high flow cat. The dc header to the cat is kinda large and the cat doesn't fit over top like I thought it should. The cat fits over the stock header fine but I want to use the dc sport..
I took some pictures with my phone to kinda give you an idea of what I'm tring to say. Is this kind of gap normal? If I bolt this up tight will I have any problems/leaks?
Old Jun 10, 2007 | 02:50 PM
Flashmn's Avatar
Default Re: Installing exhaust system (EJ8 Kenobi)
Yes its supposed to be like that, it has a tapered end and it tightens up so that it doesnt leak. Normally I've seen those in opels, they have bolts with springs on them to keep the pipe under tension and yet letting it expand due to heat.
Old Jun 10, 2007 | 05:08 PM
stumpyf4's Avatar
Default Re: Installing exhaust system (Flashmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">Yes its supposed to be like that, it has a tapered end and it tightens up so that it doesnt leak. Normally I've seen those in opels, they have bolts with springs on them to keep the pipe under tension and yet letting it expand due to heat.</TD></TR></TABLE>
Old Jun 11, 2007 | 01:35 AM
EJ8 Kenobi's Avatar
Default Re: Installing exhaust system (stumpyf4)
yeah the springs sounded like a good idea, but I didn't have any available to me so I just bolted it nice and tight. I also got an apex-i world sport cat-back to go with that setup. looks nice, haven't started it up yet though.
Old Jun 11, 2007 | 03:17 PM
92civicfreak's Avatar
u could get any of these springs off of pretty much any honda (if urs doesn't have them) at a junk yard... cheap!!! bring PB Blaster
Old Jun 12, 2007 | 05:48 AM
EJ8 Kenobi's Avatar
Default Re: (92civicfreak)
I'm not sure if mine had one or not because the exhaust was stolen.
Old Jun 12, 2007 | 12:49 PM
well i am sure it did... most honda/ acuras i have seen have them... this is from years 88-00... ur chances of finding them in a junk yard are not slim at all
Old Jun 12, 2007 | 09:31 PM
EJ8 Kenobi's Avatar
I'll be going soon so I'll look.
I have an issue with the resonator on the cat back resting against the side of the chassis section that is made for the exhaust to fit through. So when the car is up to temp and im at idle is vibrates. But the sound of the exhaust is very very nice!
samsong
Aug 21, 2007 09:37 PM
91SiZ6
Jul 1, 2006 03:58 PM
sik94hatch
Apr 5, 2006 12:50 PM
josh200536
Jun 29, 2005 03:47 PM
MenaceL.A.671
Sep 15, 2004 03:23 AM
