Is this an OEM locking lug nut?
A tool or set similar to this will suffice...
http://www.arizonatools.com/to...N2840/
If you know anyone who's a mechanic or works at a tire shop, you might be able to borrow it without having to buy it!
Even if those are factory, keys may be unavailable without knowing the key code for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrofish420 »</TD></TR><TR><TD CLASS="quote">A tool or set similar to this will suffice...
Even if those are factory, keys may be unavailable without knowing the key code for it. </TD></TR></TABLE>
From what I've researched, I believe there are only around 10 different keys for the oem locking lug nuts. My plan was to stick silly putty over the lug nut to make an impression that I could match with one of the dealership keys, since I can't drive the car.
However, I'd like to rule out if it's OEM or not, than take it from there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago »</TD></TR><TR><TD CLASS="quote">thats not oem</TD></TR></TABLE>
thats not what I wanted to hear
Thanks for the heads up though, I'll start thinking of other options
That looks like it's from Gorilla Locks.
Those are pretty good, I had them on my old CRX.
It's easy to get it out, just hammer in a 12 point socket and impact it out if you do not have the nut remover kit.
And no that nut is 100% ok, that is how it is.
In case you're stuck in the same boat it came off with ease with a 12 point 21mm socket and a couple of whacks with the hammer. I'm sure Gorilla locks are glad to hear that... And the rims sold the same day
YoungMoneySi
Jun 18, 2009 04:26 PM
