b series A/C swap on civic
i have heard by using the del sol ac bracket, i can still keep using the whole d series ac set up for the b series swap in a eg civic.
the question is, which ac belt do i use? the b series or d series?
i'm pretty sure you can use the d seeries belt, i'm using the b sreies bracket and only have two bolts going into the d series a/c compressior and every thing lines up and seems to be holding up well. and bels still in good shape
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">i have heard by using the del sol ac bracket, i can still keep using the whole d series ac set up for the b series swap in a eg civic.
the question is, which ac belt do i use? the b series or d series?</TD></TR></TABLE>
I need to know this also...so only a del sol ac bracket will work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lord Milferdeen »</TD></TR><TR><TD CLASS="quote">Dont use either. A/C is for the weak.</TD></TR></TABLE>
A/c is for those who like to drive comfortably and not get to work with a sweaty back.
You'll need the del sol ac bracket, and the B-series a/c components. D-series fan will work.
But I guess the d-series a/c compression/belt will work according to the above guy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
i hope it does...i just bought a complete ac system off a d-series
if u have the complete system and have to charge it anyways use all the d series stuff and use the b series a/c compressior it should be able to work together, the way the comprsior mounts is alittle bit different between the two
so its either...
1) Use the d-series compressor with a Del Sol AC bracket, or
2) Use a b-series compressor with any b-series bracket?
...i dont want to have to buy another compressor as I already have the d-series compressor..
...sorry for hi-jacking this thread
If your going to use a B series compressor i believe youll need to change the lines for B series. Easiest thing to do is get either the Del Sol or CRV bracket and reuse your D compressor.
If you use a B series compressor your going to need an integra AC bracket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">If your going to use a B series compressor i believe youll need to change the lines for B series. Easiest thing to do is get either the Del Sol or CRV bracket and reuse your D compressor.
If im using a D compressor, do I need a AC bracket from a D-series Del Sol? Or B-series Del Sol?
camoxiong
Aug 14, 2014 01:51 PM
JDMCRX
Jun 18, 2009 05:11 PM
B16Civic93
Mar 28, 2009 06:25 PM
greddy2smoke
Jul 12, 2007 05:31 PM
Mentat Ghola
May 14, 2005 05:48 AM
