how much boost a gsr bottom can take?
Old Jun 9, 2007 | 10:01 PM
delsoldrew's Avatar
Default how much boost a gsr bottom can take?
how much boost can a gsr bottom end handle with stock internals compared to a eagle h beam rod with je pistons combo stock bottom end?
Old Jun 9, 2007 | 10:06 PM
Luserkid's Avatar
Default Re: how much boost a gsr bottom can take? (delsoldrew)
I blew at about 350whp on a SC61 (saw it coming down from a 15psi spike)
Old Jun 9, 2007 | 10:22 PM
doood's Avatar
been there done that
Default Re: how much boost a gsr bottom can take? (Luserkid)
300-350whp on a healthy engine with a good tune
with rods and pistons, depends on the rest of the setup
Old Jun 10, 2007 | 08:37 AM
erixxxhouse's Avatar
Stock B16 blew up at 22lbs. It was around 300hp. Im not sure if you can compare the b16 with the GSR but I hope that helps.
Old Jun 10, 2007 | 08:40 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (erixxxhouse)
Technically, the bottom end can handle 500-600 whp, the head/valvetrain is a different story.
Old Jun 10, 2007 | 08:45 AM
Luserkid's Avatar
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Technically, the bottom end can handle 500-600 whp, the head/valvetrain is a different story.</TD></TR></TABLE>
Not stock. Sleeves yes, internals no. Head last longer then block sometimes (like in 2 of my cases)
Old Jun 10, 2007 | 08:56 AM
cambopheonix56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erixxxhouse &raquo;</TD></TR><TR><TD CLASS="quote">Stock B16 blew up at 22lbs. It was around 300hp. Im not sure if you can compare the b16 with the GSR but I hope that helps.</TD></TR></TABLE>
What size turbo? must have been untuned.
Old Jun 10, 2007 | 08:57 AM
Ek Forever y0!
Default Re: (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">
What size turbo? must have been untuned.</TD></TR></TABLE>
x2. Most stock internalled B's are capable of 300-350 whp with a good tune.
Old Jun 10, 2007 | 01:23 PM
doood's Avatar
that must have been one small turbo. 22psi for 300hp? most medium sized turbo's only need 10-13psi to break 300hp.
Old Jun 10, 2007 | 02:55 PM
smileycvc's Avatar
are you serious?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">x2. Most stock internalled B's are capable of 300-350 whp with a good tune.</TD></TR></TABLE>
isnt that a contradiction?
Old Jun 10, 2007 | 02:57 PM
Ek Forever y0!
Default Re: (smileycvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">
are you serious?
?</TD></TR></TABLE>
Yep.
isnt that a contradiction?</TD></TR></TABLE>
Nope. I already said that the valvetrain/head would give out before the bottom end, the OP asked what the bottom end could handle. He had no mention of the head. A well built head with a stock bottom end is capable of those numbers.
Old Jun 10, 2007 | 03:01 PM
smileycvc's Avatar
Nope. I already said that the valvetrain/head would give out before the bottom end, the OP asked what the bottom end could handle. He had no mention of the head. A well built head with a stock bottom end is capable of those numbers.</TD></TR></TABLE>
Do you have any examples of that? A stock block B series making 5 to 600 whp sounds crazy.
Old Jun 10, 2007 | 03:02 PM
doood's Avatar
500-600whp from a stock b doesnt sound plausible. like someone else said earlier, stock sleeves, sure. stock rods and pistons, doubtful.
Old Jun 10, 2007 | 03:08 PM
Ek Forever y0!
Do you have any examples of that? A stock block B series making 5 to 600 whp sounds crazy. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">500-600whp from a stock b doesnt sound plausible. like someone else said earlier, stock sleeves, sure. stock rods and pistons, doubtful.</TD></TR></TABLE>
Exactly. The sleeves would maintain. Pistons and rods are unreasonable.
Old Jun 10, 2007 | 03:11 PM
doood's Avatar
you're just pushing the sleeves to their absolute limit at those power levels
Old Jun 10, 2007 | 03:16 PM
Boost_V's Avatar
Default Re: (doood)
I doubt 5-600 hp could last a few runs at the track. Not saying it's not possible though, because i think a while back i was reading in the FI section about ppl's best whp with their stock engines.
Old Jun 10, 2007 | 05:41 PM
RedEj8's Avatar
Default Re: (Boost_V)
https://honda-tech.com/zerothread?id=1478127
read
Old Jun 10, 2007 | 06:58 PM
Ek Forever y0!
Default Re: (RedEj8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEj8 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1478127
read</TD></TR></TABLE>
#1 on the list is 600 whp.
Old Jun 10, 2007 | 07:02 PM
Boost_V's Avatar
read</TD></TR></TABLE> exactly the thread i was talking about nice find
Old Jun 10, 2007 | 08:56 PM
flipldls's Avatar
all you need is a good tune and that all parts are in well condition and it can make its 300+whp
Old Jun 11, 2007 | 04:24 AM
mikeycivic's Avatar
Default Re: how much boost a gsr bottom can take? (flipldls)
x10
look on evans tuning http://forums.evans-tuning.com...4d28f
Old Jun 19, 2007 | 12:36 PM
delsoldrew's Avatar
Default Re: how much boost a gsr bottom can take? (mikeycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">#1 on the list is 600 whp. </TD></TR></TABLE>
thats crazy numbers for unsleeved blocks!!!!1
Old Jun 19, 2007 | 12:37 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsoldrew &raquo;</TD></TR><TR><TD CLASS="quote">
thats crazy numbers for unsleeved blocks!!!!1</TD></TR></TABLE>
All in the tune.
Well, and the ***** of the owner.
Old Jun 19, 2007 | 12:47 PM
badboyr66's Avatar
Default Re: how much boost a gsr bottom can take? (ek forever guy)
This is kind of a loaded question..... as are every other time someone asked this.
For instance...the turbo size could vary. So turbo A may flow more than turbo B at 4k RPM
Not to mention you are only as good as your tune. All in all the answer to your question is it ALL DEPENDS
I have seen guys break at 230 hp ...
And I have seen guys break at well over 300 as well
brandynEG
Feb 29, 2012 01:08 PM
luder2_2vtec97
Aug 18, 2006 06:16 AM
hovic
Aug 28, 2005 05:29 PM
digital sol
Jan 4, 2005 02:13 PM
projectTeG
Oct 14, 2003 01:33 PM
