removing tape deck
Old Jun 9, 2007 | 02:08 PM
gohonda's Avatar
Default removing tape deck
so i take it when you remove the factory tape deck all you do is unscrew the screws on the left and right of the console?
any input to make it a fast job. i am replacing with a stock cd player.
Old Jun 9, 2007 | 02:31 PM
B18C_EJ8's Avatar
Default Re: removing tape deck (gohonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gohonda &raquo;</TD></TR><TR><TD CLASS="quote">so i take it when you remove the factory tape deck all you do is unscrew the screws on the left and right of the console?
any input to make it a fast job. i am replacing with a stock cd player. </TD></TR></TABLE>
How about you tell us make & model of your ride there sparky???
We're not mind readers here...
Old Jun 11, 2007 | 04:53 PM
gohonda's Avatar
Default Re: removing tape deck (B18C_EJ8)
hahah oops
its a integra 94 ls 2 door.
Old Jun 14, 2007 | 10:32 AM
jz98ctr's Avatar
you're gonna have to take apart a little more than 2 screws on the console itself unless you got a specialty tool and remove the bolts from the backside.
Old Jun 14, 2007 | 01:40 PM
gohonda's Avatar
Default Re: removing tape deck (jz98ctr)
so what all do i need to take apart. ???
there are screws in the back also?
Old Jun 14, 2007 | 05:24 PM
fcm's Avatar
fcm
Old Fart
Remove ashtray/lighter/cup holder assembly for access to two 8mm screws that hold oem back support, or, [this is the way I do mine] from the pass side using a 1/4" drive ratchet, 6"-8" extension, universal joint, [swivel joint] and an 8mm socket, you can reach up to the two 8mm machine screws that hold the HU to the rear support, a trouble light from drivers side will help.
The second way I find a lot easier and less work, and you will need the oem rear support brace for the aftermarket HU.
It is almost the same as the G2, just a little harder to get to screws... http://www.installdr.com/Insta...9.pdf 94
Old Jun 14, 2007 | 08:08 PM
jz98ctr's Avatar
Default Re: removing tape deck (fcm)
i usually use a skewdriver with an 8mm swivel from behind...works pretty good
SHG_Claudio
Jul 8, 2009 05:58 PM
IntegraAlteeza
Jul 27, 2005 08:07 AM
Speed_69
Audio / Security / Video
Apr 20, 2005 12:49 PM
seer_claw
Mar 1, 2004 05:28 PM
ichibano
Apr 18, 2003 09:38 AM
