Something new.
Old Jun 8, 2007 | 11:11 AM
laserspeeddemon's Avatar
Default Installing a GSR manifold on a B16.
I have a chance to get a GSR intake manifold for pretty cheap. I would love to throw this on my Civic to see what happens.
Has this been done before? Thread? Links?
Any help would be appriciated.
Old Jun 8, 2007 | 11:12 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Something new. (laserspeeddemon)
The bolt pattern is different between the b16 and gsr intake manifolds.
Modified by ek forever guy at 12:32 PM 6/8/2007
Old Jun 8, 2007 | 11:27 AM
alacard's Avatar
the title says on a b16...so im assuming he has an si.
Old Jun 8, 2007 | 11:32 AM
Ek Forever y0!
Default Re: (alacard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">the title says on a b16...so im assuming he has an si.</TD></TR></TABLE>
Saw that, thanks. Fixed it.
it's not compatible anyway.
The coolant ports on the GSR manifold do not meet up with the coolant ports of a PR3 head. You have to cut and weld and it's definately not worth it. Plus, if you are putting a GSR manifold on a B16, not only do you have to go through the haslte of all that fabrication, but then you still need a different ECU to control the IABs
Old Jun 8, 2007 | 01:55 PM
What are IABs?
Are you referring to the plates that switch the runner length?
Old Jun 8, 2007 | 01:59 PM
Relic1's Avatar
Default Re: (laserspeeddemon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laserspeeddemon &raquo;</TD></TR><TR><TD CLASS="quote">What are IABs?
Are you referring to the plates that switch the runner length?</TD></TR></TABLE>
correct.
VERY not worth the time, an ITR intake mani would be your best bet.
Old Jun 8, 2007 | 02:04 PM
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">
VERY not worth the time, an ITR intake mani would be your best bet.</TD></TR></TABLE>
Perhaps, but I will likely just live it the way it is.
92b16si
Dec 11, 2006 04:52 PM
maka
Mar 25, 2005 06:00 AM
ONISHIMA
Nov 30, 2004 12:55 PM
fizic
May 17, 2004 09:13 PM
Biggmike92vx
May 16, 2004 08:02 PM
