gsr manifold on a b16?
Re: gsr manifold on a b16? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Couldnt a SI/Type R IM fit a GSR with redrilling? So couldnt the same go the other way? (atleast thats what i thought) </TD></TR></TABLE>
It takes more than redrilling. The coolant ports on the GSR manifold do not meet up with the coolant ports of a PR3 head. You have to cut and weld and it's definately not worth it. Plus, if you are putting a GSR manifold on a B16, not only do you have to go through the haslte of all that fabrication, but then you still need a different ECU to control the IABs. Waste of time, effort, and money if you ask me
Re: gsr manifold on a b16? (b16a ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio »</TD></TR><TR><TD CLASS="quote">
It takes more than redrilling. The coolant ports on the GSR manifold do not meet up with the coolant ports of a PR3 head. You have to cut and weld and it's definately not worth it. Plus, if you are putting a GSR manifold on a B16, not only do you have to go through the haslte of all that fabrication, but then you still need a different ECU to control the IABs. Waste of time, effort, and money if you ask me </TD></TR></TABLE>
May be a waste of time but there is a damn good reason that Eriks racing does this. This mani is cheap to pick up, hollow out everything on the inside w/ a carbide bit, make it a B16 head. you have a HUGE plenium mani.
tempsohc
15
07-14-2011 06:08 PM
