What do you need to drop b18b in a 96 civic cx?
Old Jun 4, 2002 | 12:22 PM
EVOTHIS's Avatar
Default What do you need to drop b18b in a 96 civic cx?
Motor mounts. a/c compressor? wiring etc......
I need everything that it will need down to nuts and bolts.
Thanks.
Old Jun 5, 2002 | 02:37 AM
EVOTHIS's Avatar
Default Re: What do you need to drop b18b in a 96 civic cx? (b18c ya)
nobody has put one of these in a 6th gen civic?
Old Jun 5, 2002 | 02:56 AM
97hb's Avatar
You need a 99 civic si driver side mount(bolts into the block below the cam sprokets). A 99 civic si rear tranny mount, a 94-97 del sol ac bracket(p54 if I remember correctly) Front tranny mount will be intergra. Rest are stock. You will need a obd2 motor for easy wiring, the shift linkage out of a 94-on teg, all the fluids and some misc things to get a dealer. I got all the wiring info from Trey's website(jpec tunning? forgot the website ) If you get a USDM engine you will have a cel code 91. If you get JDM don't worry about this.
slopoke1989
22
Jul 23, 2009 08:53 PM
silver_96_teg
May 10, 2005 09:29 AM
Burke
Jan 22, 2004 06:44 PM
imlachg1
Jan 12, 2004 02:25 PM
vladd
Dec 8, 2002 12:00 PM
